Turn signal malfunction - 1994 900s - SaabCentral Forums
Old 11-02-11
rhcple rhcple is offline
My Saabs: 1994 900s
Default Turn signal malfunction - 1994 900s
My turn signals were working intermittently and have now stopped altogether. The hazards don't work either. The highbean switch is on the same stalk and that is working fine. The stalk will engage but the lights won't go on and it doesn't show up on the instrument panel either. Could it be the relay switch or do you think I have to replace the entire turn signal mechanism?
I would really appreciate any advice and also info on how to take apart the dash to get at these things...
Thank you!
Old 11-02-11
TooMany2cvs's Avatar
TooMany2cvs TooMany2cvs is offline
Saabista
My Saabs: '90 900T16 3dr - For Sale!
I'd start by replacing the hazard switch. It "cuts out" the indicators when operated, and it can certainly have a sulk which'll leave you with nothing flashing.
Adrian
Soon to be living life on the road in an old VW
http://WhereverTheRoadGoes.com
Old 11-02-11
My Saabs: 1994 900s
Thank you for replying. I just joined the forum and was excited to see a post to my thread! I will look into what you said but I am not having a problem with the hazard button malfunctioning - it pushes in and pops out as it should which doesn't seem to indicate a switch failure...
Old 11-02-11
Saabista
Ah, but you don't know what's happening inside it...
Adrian
Old 11-02-11
Dans_t16s Dans_t16s is offline
My Saabs: T16S
1994 900s
Classic 900 or GM900 ??
Dan.
Old 11-02-11
My Saabs: 1994 900s
Its a GM / NG
Old 11-02-11
My Saabs: T16S
May I suggest you try the correct form.
Dan.
Old 11-02-11
My Saabs: 1994 900s
Oops, I'm sorry! I will post on the NG forum. I apologize for wasting your time. Thanks for the heads up.
Tags
electrical, lights, relay, turn signal
Similar Threads
ELECTRICAL: fog lights only turn on when the turn signal is on saab1995conv Saab 9-3 & NG900 Workshop 3 28-05-10 08:06 AM
Turn signal stuck in left turn?? mmayson Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 16 28-03-10 11:37 AM
turn signal racerx0140 Classic Saab 900 Workshop 1 01-10-08 02:15 PM
Turn Signal nick04 Saab 9-7X 0 25-06-08 06:17 PM
Turn Signal wantasaab Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 1 13-05-03 08:13 AM
