Power Steering problem - SaabCentral Forums
Old 7th February 2011
paulman paulman is offline
My Saabs: Ireland
Default Power Steering problem
My '06 9-3 power steering has a strange problem. While turning the power steering fluctuates from being smooth to a loss of power. I can only describe it as if there was a belt that power assists but then the belt continually slips making it more difficult to turn.
Any ideas on possible causes?
xp3's Avatar
xp3 xp3 is offline
My Saabs: '03 Saab 9-3 2.0t
Did you check power steering fluid level?
You might have a leak and the pump will struggle.
Did you hit any pothole recently?
Belt failure is an option but only on petrol engines.
Current mods: 14t swap w/ JZW tune, GS Strut Brace, Aero front lip, 9-5 Aero turbine wheels,
(check out my for-sale-thread)
Coming soon: downpipe/exhaust, Aero body kit
My other SAAB is a car.
My Saabs: Ireland
Fluid level is fine.
It is a Petrol 2.0 Aero.
I could check for leaks but I'd appreciate hints on where to look as I'm not familiar with the Power Steering arrangement. I want to rule out as much as possible before I hit the garage as they are notorious for turning simple problems into expensive fixes.
aerojon's Avatar
aerojon aerojon is offline
Smile
not on the 4 cyl SS,pump is driven by the camshaft..
you changed your pump seal not so long ago aswell..
Is still running factory oe coils with Hirsch tune..
Old 16th February 2011
My Saabs: Ireland
the diagnosis is a loose power steering lug - any pointers on how to fix this or is a new one needed?
aerojon's Avatar
Smile
SaabMick's Avatar
SaabMick SaabMick is offline
My Saabs: 09 9-3SC Aero XWD 6MT - Stage 5
Garage
I'm guessing it needs to be tightened...
1999 Saab 9-3 SE HOT - gone
2006 Saab 9-3 2.0T - gone
2006 Saab 9-3 Aero SportCombi - "the beast" JZW Tuned Stage 5 - RIP
2009 Saab 9-3SC Aero XWD 6MT - JZW Stage 5
My Saabs: Ireland
I didn't quite understand what he was telling me but I think it is actually a Knuckle join on the steering column that was loose or broken but it was causing the steering to stiffen and loosen.
aerojon's Avatar
Smile
can see the steering uj causing this symptom..
what engine have you?
Old 17th February 2011
My Saabs: Ireland
it's the 2.0 aero. The repair cost will depend on whether the knuckle join can be sourced independently or a new rack is needed...
aerojon's Avatar
meant to be "can't" not "can"
Old 1st October 2016
Shagn Vagn Shagn Vagn is offline
New Member
My Saabs: 2006 9-3 Sportcombi Aero
Default U joints cured steering issue
Just wanted to chime in on this issue.
I've only had my 06 9-3 Aero Sportcombi less than a year.
Steering was a bit tight on cold mornings, but nothing too troubling.
We've had a really hot summer, and my steering got progressively tighter and tighter all the way through the radius. I'm thinking as posted before the air conditioner condensation was seizing the u joints.
My garage lubricated (soaked) the u joints overnight. It took about a week for them to fully free up, but the problem is 100% fixed.
Just wanted to point others to this easy fix!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Power Steering problem Damvers222 NG900 & OG9-3 Workshop 5 31st July 2009 08:36 AM
Power steering problem? blackjak 9-5 Workshop 5 18th September 2008 08:13 AM
power steering problem maciekb2002 9-5 Workshop 1 10th October 2007 08:10 AM
Power steering problem??? Alesin 9-5 Workshop 5 23rd July 2007 09:12 AM
Power Steering Pump Problem richsurf NG900 & OG9-3 Workshop 8 15th September 2004 11:45 AM
