Cruise Control 92 900 vert - SaabCentral Forums
Old 30th January 2011
RustyNuts's Avatar
RustyNuts RustyNuts is offline
My Saabs: 92 900 T16 Vert
Default Cruise Control 92 900 vert
Cruise light will come on but it will not engage. I've check everything but the relay, or is there a relay? All vacuum hoses are attached and appear not to be dry rotted.
Is there any thing else to check? Could the unit by the driver side quarter panel be bad and I just can tell it by looking at it?
Any suggestions?
Thanks===rn
ursatz's Avatar
ursatz ursatz is offline
My Saabs: '90 900 turbo convert
Good diagnostic page: http://townsendimports.com/Web/elect...isecontrol.htm
My experience is that the cruise vacuum controlled switches can leak with time. I had temporary luck "fixing" them with some plummers silicone to make a better seal, but ended up replacing.
Also, there is a switch that limits boost when the cruise is activated that is also prone to leak. I bypassed mine completely.
Be prepared to pull the knee pad and have some spare vacuum hose on hand for tests or replacement.
Good luck!
16saabs 16saabs is offline
My Saabs: 2x LPT convertible's, 1 x 900 SE
or has the actual switch on stalk failed
22saabs
RustyNuts's Avatar
Wow, that looks like a weekend job. Thanks for the replay and the article. What switch on the stalk are you referring to 16?
the cruise control switch is part of the indicator stalk on UK I think or the other side(never had cruise on my 900's, but know someone who has)
22saabs
RustyNuts's Avatar
Are you talking about the one behind the drivers headlight behind the panel?
ursatz's Avatar
I'm talking about the vacuum switch behind the brake/clutch pedals.
Old 31st January 2011
JKlaveness's Avatar
JKlaveness JKlaveness is offline
My Saabs: 94 900 vert (2x), 93 900 4d, 97 9000 CSE
I've had 3 'verts ('92 & 2x94), all of them with the same problem: The cruise control would sometimes work ... and then sometimes not. It seems to be completely random. The only trend that I'm suspecting might be there, is that it helps to have the heat on high ... but it might be imagination. If it's a trend, it's weak.
I've run through the entire troubleshooting chart from the Bentley Bible (excellent chart by the way). Every single component seems to work flawlessly. No leakage from any of the vacuum switches. I've taken the stalk switch apart and put it back together. Still no improvement.
I'm mystified, and interested in all responses to this posting.
d_ames117 d_ames117 is offline
My Saabs: 92 900T Convertible, 08 9-3 2.0T
Same problem here. When it was new and under warranty we took it to the dealer at least a hand full of times to correct the problem. They always said it was fixed or "we couldn't duplicate the problem." Once, I was driving and the cruise was working fine, and all of a sudden, it just stopped working and wouldn't re-engage. It's still intermittent.
Dustin
just keep the foot at the same angle works just as well
unfotunately or fortunately we don't have 'LONG' roads where we can use this feature for long anyway in uk, as there is always someone jamming on there brakes in front on the M-ways
22saabs
Old 6th February 2011
RustyNuts's Avatar
Well then, can we swap parts?
I have a 'scrap' C900 turbo vert and that's fiited with cruise, the car will be stripped out in the warmer weather, for parts for our own(hence purchase), but non of us have cruise(5 x900's) if you have'nt been successfull in finding parts(sorting prob) give us a PM
22saabs
Jim Mesthene's Avatar
Jim Mesthene Jim Mesthene is offline
Saabista
My Saabs: Wife's 9-3
Default Cruise Control Common Faults
These are the common weak points:
1988 or older- Bad vacuum lines
1989 - Bad Speed Sensor
1990 or later - Misadjusted or faulty Pedal Switches
Of course, your car may have its own individual problem.
You can manually power the Vacuum Pump and watch the Throttle open to check the mechanical portion of the system.
"Those who can make you believe absurdities, can make you commit atrocities".
- Voltaire -
JKlaveness's Avatar
Thanks, Jim. I'll give the pedal switches a good looking over when I take the Norwegian 'vert out of winter storage. That'll be in April, I hope.
:-J
James Bond James Bond is offline
My Saabs: 1994 T Conv. 2000 P38 Range Rover
Did you check the signal from the speed transducer and also how do you check if the ecu is good? (I have the same prob!).
Old 10th May 2011
JKlaveness's Avatar
I took the 'vert out of winter storage a month ago, but only got around to checking the Cruise Control today. Took me 3 hours.
* There are no problems in the cable harness. I tested every single cable, and found excellent connectivity everywhere.
* The whole vacuum system works flawlessly. I can run it manually by feeding 12V into the cable harness from the CC Electronic Control Unit under the dashboard (+ to pin 1, - to pin 6 & on/off to pin 7).
* The pedal switches are reliable and do exactly what they're supposed to do.
* All voltages and signals get through to and from the cable harness for the electronic control unit, as described in the wiring diagram.
There are two things left that I don't know how to check.
1) The speed transmitter behind the instrument panel gives out a steady 12,7V (full battery voltage) on pin 2 when the car is stationary. The moment it starts to roll, the voltage drops to 6,69V. The voltage seemed to rise a little when I drove fast, but the difference was small (7,2V at 100 km/h), and there was some fluctuation.
2) The electronic control unit under the dashboard might be faulty.
I have both a spare speedometer (with a speed transmitter) and a spare electronic control unit, but both came from a car with exactly the same problem as my present 'vert, so I don't think I'll learn anything from starting to switch parts around.
Should I just give it up, and accept that I only have a Cruise Control now and then?
I drove the car for 6 hours yesterday, all the time with the heat on high. The CC started to work after about 1 hour, and kept working until I had to take a 1 hour break because of a ferry ride. When I drove off the ferry, the car was cold, and I didn't get the CC to work again ... but I had a LOVELY ride home nevertheless. It was as dark as it gets in Norway on a summer night, and I can attest that dew does amazing things to how a landscape smells.
:-J
Old 11th May 2011
vsfoxe's Avatar
vsfoxe vsfoxe is offline
My Saabs: 90 SPG, 86 Airflow, 91 SE, 92T, 99 9-5SE
My experience and lots of reading tells me that on '92 and newer, the electronic unit (brain) is the most common problem. The '91 and older did not have this problem, but the brains won't interchange without rewiring. My '93 turbo used to work fine sometimes, quit working when it felt like it, start working again, and so on. I swapped the brain out and it worked fine from then on. Vern
Old 11th May 2011
JKlaveness's Avatar
Thanks a million. I'll turn my attention away from the speed sensor for the moment, and focus on the ECU. Since I have a spare, I can open it up and look at the circuit board and connections inside. Maybe I'll find something. And if not, spares seem to go for around $50 on ebay.
:-J
Jørgen
Old 11th May 2011
rawill's Avatar
rawill rawill is offline
My Saabs: 06 93 2.0,93 9000griffin 92 900s LPT vrt
Great reading - I will follow it with interest. My 92 Cruise Control works fine, but who knows. Mine came from Singapore.
03 V6 Renault Laguna! 06 93 Linear 2.0t, 93 9000 griffin 2.3 St-II. 93 9000CSI na man,350,000km. 92 900 S LPT vert.
Old 11th May 2011
JKlaveness's Avatar
My interpretation of the fluctuating voltage from the speed sensor
>> 1) The speed transmitter behind the instrument panel gives out a steady 12,7V (full battery voltage) on pin 2 when the car is stationary. The moment it starts to roll, the voltage drops to 6,69V. The voltage seemed to rise a little when I drove fast, but the difference was small (7,2V at 100 km/h), and there was some fluctuation.<<
is that the sensor is sending out pulses, with a frequency that depends on the speed of the car. If I had access to a 12V occilloscope, I could probably confirm this. An alternative, come to think of it, is to connect the signal to a loudspeaker that I don't particularly care about (or through a resistor). Might be fun to try. The worst that can happen is that the speaker burns up.
:-J
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Cruise Control 92 900 vert RustyNuts C900 Workshop 9 30th May 2010 08:45 AM
Master control relay for cruise control math C900 Workshop 13 18th August 2006 04:27 AM
Cruise Control taking over control kazmiekr NG900 & OG9-3 Workshop 2 11th August 2004 11:49 AM
Cruise control still won't work. What now? Any cruise gurus? RM '92 SPG C900 Workshop 8 13th July 2004 05:29 AM
Anyone ever install cruise control into non-cruise 900? GlobalSport C900 Workshop 3 16th January 2004 06:55 AM
