fuel cut, oowwwwwww - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Performance, Mods & Tuning
Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900
Old 19-01-11
bazsaab bazsaab is offline
My Saabs: 1991 t16s vert
Default fuel cut, oowwwwwww
hi all.i,ve done my mod's to my 91 t16s & now i have fuel cut .posting earlier i knew about the under dash adjustable switch (which isn't there) so i thought i would be safe, tho i'm not .any advice on how to beat the dredded cut would be apprecated .my car run's very well & strong apart from this (brick wall) cut.cheers barry
NOTICE . thank you for noticing this new notice ! you're noticing has been duly noted !..
Old 19-01-11
ianrobbo's Avatar
ianrobbo ianrobbo is offline
My Saabs: 1989 T16S T5
Garage
You say you're getting fuel cut - when does it happen, and what does it feel like?
I got fuel cut before I disconnected my fuel cut off switch, and it was a real headbutt the screen moment when it happened.
It's hard to find, and surely you must have one - otherwise, whats cutting the fuel?
You could always T5 it - then you can adjust the fuel cut in the comfort of your own laptop.
Old 20-01-11
c900's Avatar
c900 c900 is offline
My Saabs: 81 8V 900T, 91 2.1 900i, 90 9k 2.0 Carly
The overboost pressure switch lives behind the relay holder under the left hand side of the dash where the flasher relay and wiper relay are hanging out.
Craig.
Craig Dewick - Wollombi/Laguna, NSW, .au- Websites Flickr - 23 - Saab C900's - Saab 99's - Saab 9000's - Free non-commercial Classic Saab albums and Classic Saab forums - RIP Moose.Parts which these forums still ILLEGALLY censor any mention of in postings!
Old 20-01-11
ianrobbo's Avatar
Garage
Craig.
Craig, I think Baz has been struggling to find his overboost cut off:
http://www.saabcentral.com/forums/sh...d.php?t=191533
It was suggested in that thread that later cars may not have had one, in which case what is cutting his fuel? That's why I asked what it feels like, as maybe it's not overboost fuel cut, maybe some other problem?
Anyway, Baz, mine is a 1990 model year T16S, UK car, Lucas (before I T5'd it), and mitsubishi TE05 turbo, very similar spec to yours, and mine definitely has an overboost fuel cut off switch behind the dash, accessible either through the passenger side windscreen air vent/speaker grille, or after removing the knee bolster.
Old 20-01-11
TheAlien TheAlien is offline
My Saabs: 1991 Saab 900 Turbo
Might be obvious, but sometimes one forget the obious: The tank is more than half way full? My fuel pump fails to pump on very hard acceleration when the tank isn't full...
Old 20-01-11
hi ian,i've had modded turbo car's in the past & this is just the same i.e. drop down a gear to overtake floor it & headbutt the screen, as you say.when i prepped for my mods i looked through the speaker hole & nearside kneeroll location for an adjustable switch but as you know i found nothing. perhaps i was looking for something from an earlier version .our specs are the same so where was your's & what did it look like & how did you disconnect it ?.cheers barry.p.s. what does t5 it mean ? .
Old 20-01-11
philjohnhb's Avatar
philjohnhb philjohnhb is offline
My Saabs: Black T16 'Carlsson' vert and 9-5 Aero
It is circular in shape, about 3cm in diameter, 2 vacuum pipes going in/out and 2 wires connected. In the centre of the disc is a shrouded screw adjuster, clockwise to increase threshold and anti to decrease. I just removed both wires and connected to each other.
If going in from the knee bolster it is mounted behind the relays (wiper included). Unscrew the self tappers that hold the relays to the bulkhead, pull them away and you should then see the switch up and behind.
Phil H-B My Carlsson Convertible Project Thread
Originally Posted by Jim Mesthene
Other pieces of your car could fall off, if not bolted on.
Our holiday cottage website www.amblesidecottagelakedistrict.co.uk www.bonniecottages.co.uk
Old 20-01-11
ianrobbo's Avatar
Garage
Barry,
Because of the angle of the screen, you can't get your head in far enough to see the switch (unless your head is smaller than mine!), and I think it's hard to see it through the screen from the outside.
Get your arm in there, and feel around for the vac hoses - you know the things, the little rubber pipes. If memory serves, there are 2 pipes - one going in, one going out, to the boost gauge.
You need to disconnect both, and join them together with a short bit of rigid pipe. That way you don't need to mess with the electrics, and the boost gauge still works.
T5 is Trionic 5, the engine management system used on Saabs from 94 on.
See this thread:
http://www.saabcentral.com/forums/sh...d.php?t=162197
Old 20-01-11
that was what i was looking for when i did my prep , 99% sure it was'nt there !.tho that 1% say's look again.thanks & cheers barry.
Old 20-01-11
Barry,
See this thread:
ahh yes that would explain why i could'nt see it from above.i'll try the arm thing assuming mine arn't bigger than your's .t5 got ya , thought it might have been something to do with v**vo's .after all i know they use our stuff .thanks & cheers barry.
Old 20-01-11
can't be mate , as i consider my tank empty when it's half full .
Old 20-01-11
Craig.
craig,i'm going to be there again soon, hopefully with a result .cheers barry.
Old 21-01-11
ha ha ha ha, fuel cut is no more .thanks for all the advice it rearly was appreciated.i went in by the speaker hole & simply disconected all my arm ,wrist & finger joints & did what had to be done.wow .no WOW she goes well now.just the one point, knowone told me to look out for the sharp metal bits through the speaker hole , so now i can hardly type, my hands are covered in plasters ,tho it was well worth it.thanks again .cheers barry .
Old 21-01-11
ianrobbo's Avatar
Garage
Well done mate, got there in the end
Old 21-01-11
thank you sir , you are a star .
Similar Threads
1978 99L U.S. Fuel Accumulator bypass. What size Threads? Fuel Filter inplace maybe? AndrewSaab Saab 99 & 90 Workshop 1 07-08-10 07:51 PM
Where is Fuel Pump Relay? / Carb cleaner in a fuel injected engine? jsimma Saab 9-3 & NG900 Workshop 5 14-02-09 01:35 PM
Why do the fuel pump assemblies and fuel pumps have diff. part #s? Leon Saab 9-3 & NG900 Workshop 6 07-04-08 11:26 PM
Replacing fuel pump w/dropping the fuel tank. 1999 9-3 anarchyx34 Saab 9-3 & NG900 Workshop 16 25-11-07 04:42 PM
Fuel gauge reads empty, fuel light on, but tank full. saabtour Classic Saab 900 Workshop 2 01-08-06 02:38 PM
