Clutch Change - SaabCentral Forums
Old 18th January 2011
SAABBSR SAABBSR is offline
My Saabs: 2006 9-3 2.0t JZW Stage 3
Default Clutch Change
Putting in a new spec clutch and new flywheel, as well as the slave cylinder. Doing it myself to save a few bucks. Anyone have a link to a site that has a detailed explanation as to how to do the clutch change? Thanks for the help.
Saab 93 2006 5spd
Old 19th January 2011
bparker5512's Avatar
bparker5512 bparker5512 is offline
My Saabs: Turbo X MT VTune 0 Rev. 2
Garage
Where in CT are you? You should do mine too
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is offline
Saabista
My Saabs: Black on black '97 Saab 3-door SE Turbo
Has spec improved the clutch? I remember last year several people had major problems with them just a few weeks after the install. Genuinesaab even stopeed selling them. I haven't seen much mentioned about them lately.
Checkout Dmitry's site for the clutch change. It's written for a NG900, but you'll get the idea. Or download the WIS; just do a google search on Saab WIS.
Does your car have the Double Mass Flywheel? If so, it's pretty pricey - around $1-k... Ron
Milford
boxman boxman is offline
My Saabs: -
5 or 6 speed box ?
If you PM me your e-mail address I can send you instructions in PDF
Xl Ecclipse lX's Avatar
Xl Ecclipse lX Xl Ecclipse lX is offline
My Saabs: 2006 9-3 Aero JZW stage 3+ 357hp 476 trq
BSR you wouldn't happen to know how to replace a master clutch cylinder would you?
No I don't......
Old 20th January 2011
Last_saab_standing's Avatar
Last_saab_standing Last_saab_standing is offline
My Saabs: 2005 9-3 ss aero
i did change my clutch + flywheel for the spec last year...sitll good!
Live as if your were to die tomorrow. Learn as if you were to live forever.
dzlsabe dzlsabe is offline
My Saabs: 06 93 TiD Combi, #2 TiD Combi Running
Ive done a few, but not for over a year, so its from memory. Basically its not much different than a 95 or earlier 93.
Engine brace across the top bolted to car body suspending engine. I made a big hook to hold under PS pump. Raise on lift. Remove front tires. L & R caliper. One end of both sway links. Remove exhaust. Support radiator and condensor with bungee cord. Remove bolts holding subframe and steering rack and L ball joint. Swing subframe out of way. Remove trans and rear motor mounts. Disconnect and clamp clutch hose. Remove 18s holding trans, pull and lower on trans jack.
Only US diesel?? 03 93 Cosmic Blue
Also Black 06 93 Combi, White 89 900TCV
Old 21st January 2011
My Saabs: -
PDF files sent via e-mail tonight mate,
hope it helps
nairua nairua is offline
My Saabs: SS 2.0T Aero 2003
Garage
They still sell them.
Old 5th February 2011
My Saabs: -
I trust you received the e-mail with the info you needed, I don't know as you haven't come back and said anything
a small show of gratitude wouldn't have hurt
any way I hope it helped and I hope the job went well
Old 6th February 2011
Sorry Boxman, was away from the comp for a few days!!! Thanks for the instructions, but I wussed out and had a mechanic do the install.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
How to change a clutch??? sloopy C900 Workshop 4 25th August 2009 02:31 PM
Fun doing clutch change supremedalek C900 Workshop 0 28th October 2008 06:02 AM
Clutch change spg1 C900 Performance, Mods & Tuning 7 16th August 2008 09:36 PM
Clutch Change cammybroon NG900 & OG9-3 Workshop 5 12th March 2006 02:28 PM
clutch change and head gasket change - what parts? gazraa 9000 Workshop 26 16th May 2005 11:23 AM
