Upgrade for Td04/injectors - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Performance, Mods & Tuning
9000 Performance, Mods & Tuning Covers Tuning & Performance modifications for the 9000
Old 11th January 2011
TwinScrewPGT TwinScrewPGT is offline
Default Upgrade for Td04/injectors
Ok So I picked up a Td04-15t off ebay that was listed as rebuilt..(Turned out to be trashed and needs rebuilt). So I am looking at this. http://cgi.ebay.com/ebaymotors/SAAB-...Q5fAccessories
What are your opinions? Also My stock exhaust manifold has the Round T3 flange where as the original t-25 turbo uses the rectangular T3 flange. Just curious about this mismatch? The Td04 uses the round exhaust so it matches but it seems really restrictive compared to the T25's?
As for injectors im looking at these http://www.bmotorsports.com/shop/pro...oducts_id/1587 Opinions?
Any knowledge of a successful conversion from T5 BPC to T7 BPC for the early 93 5.2trionic systems?
Also the talk about removing the balance shafts ? Pro's? Cons?
Old 12th January 2011
Oops i linked the wrong thing. This is what I ment for the upgrade. http://cgi.ebay.com/ebaymotors/TD04-...mZ280603997319
Where is everyone or does no one have knowledge on these subjects?
Cars a 12/92 T5.2 9000 CSE FPT 5spd
Old 13th January 2011
McVities McVities is offline
could be a useful upgrade, but it'll still need to be balanced and assembled. Chances are you could probably get your wrecked turbo rebuilt (maybe upgraded too) for that kind of price.....
slightly confused here, some pictures may help......
your old T25 will most likely have used the rectangular T25 flange - this is smaller than the rectanglular T3 flange sometimes found on older 9000's.
If you have a circular hole inside a T25 bolt pattern, the turbo could have been mis-described and actually be from a 9-5
a bit overkill, the 60lb (630cc) injectors have been used over here in the UK, and need a little bit of fettling to ensure decent cold start and a steady idle. Unless you're planning to run the car on E85, I'd go with the 60lb and a re-map.
not from me I'm afraid.......have you had a look on ECUproject?
pro's: less rotational mass, therefore better acceleration and/or fuel economy
con's: more vibration, oil passageways need blanking off
Rich
900s PWR chargecooled LPT+
9000 CC Carlsson x2
9000 CS Carlsson
WRong link. I ment to post just the housing and wheel. (in 2nd post)
Ok, My exhaust manifold has the T25 bolt pattern with the round hole. The Garrett that came off had the rectangle port on the turbo. (MISMATCH <)
Now the ebay td04 has the same port as my exhaust manifold (Round) Seemed a bit odd that the factory would mis-match like that?
Well I have a guy near me that does tunes for people 1,2,3 and in-house dyno tunes, which is what ill be doing just want to get the car ready for say a stage 4ish tune.
By the blanking off you mean? blocked off?
Old 16th January 2011
ah right.....doesn't look too bad, but you'll still have to get it built into your turbo then balanced - won't be overly cheap. Also, a lot of turbo rebuilders (or other craftsmen for that matter) prefer to use their own-sourced parts.
like I said, I'm having a little trouble getting it straight in my head exactly what you have.....some pictures would be a great help.
As I understand it, the 9000 came with 2 variants of rectangular flanges - T3 on the early and then T25 on the later models (including the Aero TD-04).
Here's a comparison of the T3 vs T25
The T3 manifold is also quite different from the T25
With the later GM900, 9-3 and 9-5 a T25 flange was used, this one was circular not rectangular......but never fitted to a 9000
the 60lb injectors are good for ~500bhp, the bigger ones will be harder to set up and map for good idle and a bit overkill for stage 4.
yup. There's divided opinion on whether to remove the balance shafts completely or not, more work is involved to take them out. It has been done before, have a search on here.
Rich
9000 CC Carlsson x2
9000 CS Carlsson
KaMiKaZi_t0M's Avatar
KaMiKaZi_t0M KaMiKaZi_t0M is offline
#1 Super Guy!
My Saabs: 92 C900T vert, 95 9K Stg3+, 96 GOOSE
I'm guesingg you have a 1992-3 year 9K correct? If so, and you want to run a TD-04, you should just be able to bolt it up and bend some oil lines. If you have redtop injectors, you don't need to upgrade, those will flow just fine. As for just getting the turbine and housing, that is a waste of money. You don't need the cold side housing I'm sure (they never get trashed). If anything, get the full "core", that way it will be balanced already, or pick up another "rebuilt" or used turbo. The TD-04's from the Aero are incredibly durable, more so than their Garett counterpart. Mine is second hand from a kid who drove the piss out of the car, and it has over 200k on it and I boost 20PSI multiple times a day!
Tom
Old 24th January 2011
ok.. the last pic you showed was a t25 flange with the round port.... which is what is on my car factory.(Exhaust manifold) Now my factory T25 turbo... was t25/rectangle port. Now the new turbo that im rebuilding/upgrading has a t25/round port.. So the route im going the flanges are matching now..vs FACTORY mismatch.
Ill be rebuilding the turbo/upgrading then sending out for balancing which will run me $65. Any ideas on an optimal intake pipe size? 2 1/2 seem like overkill?
I will be going with the 60lb injectors.
Should I purchase a heftier Wastegate Actuator?
Anyone ever make their own exhaust manifold to relocate the turbo to the air filter side of the engine bay...? Im doing this now. Just need to find a decently priced collector and buy some bends. Ill get pics when ever the weather permits me to even think about walking outside.
Old 25th January 2011
hmmm.......unusual that.....round T25 manifolds.
If you have a TD-04 with a round T25 flange, it may well be from a 9-5 and have the #5 turbine - would be worth getting the part numbers checked. If it is the #5 it will be more retrictive and limit your top-end power much more than the #6 would.
2.5" intake sounds fine.....upstream of a turbo it doesn't make too much difference how big you go, just as long as it's not narrow or has many restrictive bends.
don't bother with the hassle of making a manifold, just use the GM900/9-3/9-5 manifold........it's designed to hold the turbo the opposite way to the 9000. I'm about to use it on my 1990 9000, and it all fits like a charm - gives much more room for the downpipe too. You will need some custom oil/water lines though.
Rich
9000 CC Carlsson x2
9000 CS Carlsson
Old 29th January 2011
Its almost complete.. Very simple actually. I just scanned a gasket into AutoCad and had it cut(manifold flange).. some simple stainless bends + my tig skills and now im just waiting on a collector/flange to get here then ill be all done. As for oil/cooler lines a local speed shop has me setup with stainless braided stuff.
Old 30th January 2011
rawill's Avatar
rawill rawill is offline
My Saabs: 06 93 2.0,93 9000griffin 92 900s LPT vrt
As for T7 on a 5.2 ecu.
It is certainly doable, but a little more fiddly than on a T5.5.
If you have a perfectly good T5 APC/BPC valve then there is really no need.
But if the T5 BPC goes faulty then it is a worthwhile mod, the T7 BPC is so much cheaper. See my signature, I have done this mod on my 97 CD.
03 V6 Renault Laguna! 06 93 Linear 2.0t, 93 9000 griffin 2.3 St-II. 93 9000CSI na man,350,000km. 92 900 S LPT vert.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
TD04 upgrade robw 9-5 Performance, Mods & Tuning 67 5th November 2013 03:14 AM
Wanted: Garrett t25/t28 hybrid or TD04 18/19t and Bosch green injectors Saab9-3SEHOT Parts for Sale/Wanted - North America 0 28th October 2010 12:19 AM
Wanted: 2000 SE Injectors, TD04 turbo ryanmancl Parts for Sale/Wanted - North America 1 7th April 2010 09:31 AM
TD04 Upgrade - 5 or 6cm? T9 dreamer NG900 & OG9-3 Performance, Mods & Tuning 3 9th January 2005 04:55 AM
Injectors upgrade for Lucas ECU niko C900 Performance, Mods & Tuning 13 1st April 2003 08:19 AM
