Miles to KM odometer help! - SaabCentral Forums
Old 7th January 2011
SpongeBob's Avatar
SpongeBob SpongeBob is offline
My Saabs: Peruse my photo gallery.
Default Miles to KM odometer help!
The tachometer in my instrument cluster stopped working ...so instead of repairing it I thought it would be easier and cheaper just to buy a new (used) instrument cluster. My 1999 9-3 Turbo convert has a metric speedo and odometer and the one I bought is a US one showing miles. Before I do the switch can anyone tell me if the US cluster will properly work in my car? Also is the odometer controlled by the ECU and can it be re-calibrated.
Artie Artie is offline
My Saabs: 2001 9-3 Conv
The odometer is not controlled by the ECU in these cars and stores the miles in its own memory. The odo will work in your car but show the donor's car mileage (which in some cases might be considered fraud, so be aware).
SpongeBob's Avatar
I have no idea what the new clusters odometer reading is - it may be higher or lower in any case I would disclose this if I decide to sell. But since my car's original cluster is in KL. would the replacement US unit indicate the MPH and odometer readings in miles accurately?
busaboy busaboy is offline
My Saabs: 2000 Viggen 5-door
I suppose this will upset you, but why did you buy a US-spec cluster?
I wouldn't buy a Canada-spec cluster.....
earthworm's Avatar
Saab Sage!
Maybe the dealers Tech2 ($100 to $200 per hour, one hour increments).
Your savings ?
Better to repair the OEM, IMO.
The earthworm
'96 900S, Automatic
Old 8th January 2011
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is offline
Saabista
My Saabs: Black on black '97 Saab 3-door SE Turbo
There are nearly 20 "casings" listed in the EPC. The casing is the part with the electronics, guages and lamps. The casings are either in KM/H or MPH. And there are no notes about using a Tech 2 scan tool on them like there is on the Odometer which is sold seperately... Ron
SpongeBob's Avatar
Not all upset with your reasonable question ----- I bought it in haste through Ebay.
Whew!!
Well, unless you get some pretty firm indication that it is convertible, I recommend you cut your losses early and start over!
FWIW, I checked EPC and the tach is an integral part of the instrument cluster - no listing whatsoever of separate part numbers for the individual instruments.
And, be aware that BBA (and possibly others) reman these!
Old 9th January 2011
SpongeBob's Avatar
Whew!!
Ya.. live and learn ...... for some strange reason the tack stared working again so I suspect that the problem is not in the instrument cluster but must be some loose or corroded wire ---
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
odometer and trip odometer not working... 88saab900s C900 Workshop 6 31st August 2015 06:40 AM
How'd I use twenty miles worth of gas in 1 1/2 Miles? Huh? dano1atty 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 9 24th July 2005 06:41 PM
Holy miles! Odometer no working. ethanroelle 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 3 29th July 2004 11:50 AM
2002 9-3 HOT 30K miles vs VIGGEN w/ about 45K miles abdukted1456 NG900 & OG9-3 Performance, Mods & Tuning 12 8th February 2004 04:21 AM
Odometer Help 88Saab900 9000 Workshop 1 20th May 2002 06:13 PM
