C0460 - Steering Angle Sensor Circuit Malfunction - SaabCentral Forums
Old 6th January 2011
barry5580 barry5580 is offline
My Saabs: 2005 93 TID 1.9 150 BHP
Default C0460 - Steering Angle Sensor Circuit Malfunction
My 2005 93 1.9 tid 150 bhp has been comming up with "Stability Control Failure Contact Service", had this problem for about a month now and just managed to get my OP COM on the system resulting it the following fault:
Identifier: 0x0301
Hardware number:12801327
System name: ESP EBC430
Part Number:12801324
Software version number: 00C3552E
Hardware key number:
System description: TRW 0300
Alpha code: AA
Total number of fault codes: 1
(11) - Not present
Has anyone come accross this before, can give me a pointer on the location of steering angle sensor?
Any help will be appreciated.
Cheers
gjdavies's Avatar
gjdavies gjdavies is offline
My Saabs: Saab 9-3CV Aero TTiD 180
I believe it is part of the CIM (Column Integration Module) and if reported as missing, the CIM is knackered.
...just give me ten minutes, look at the moon or something...
Cheers for quick response, I have had the drive shaft out, plus an auto lock smith has reprogrammed my cim unit and a new set of keys due to damage on the only working key.
Could this be the cause, meaning cim unit?
gjdavies's Avatar
Could be the fact that the auto locksmith has messed with the CIM and that has caused the Steering angle sensor to throw an error, may just need the SaS module re-adding.
Get a Saab Tech II unit on it at a dealer or independent specialist to be sure.
Thanks again I'll have this checked out, do you know if this an exspensive job?
Old 7th January 2011
ctrlz ctrlz is offline
Location: Ocean City NJ, 03 Vector 2.0T 6spd, BSR Stg 1
Ooooo, good answer!
That's pretty much exactly what the WIS says! After messing with the CIM the module needs to be re-added.
(silently prays that his next car has a USB port, wi-fi, or some other kind of user-hackable interface instead of proprietary nonsense like the Tech2)
Old 8th January 2011
dzlsabe dzlsabe is offline
My Saabs: 06 93 TiD Combi, #2 TiD Combi Running
Steering angle sensor/clocksprings, as well as turn and wiper switches can be replaced fairly easily, sparing a CIM replacement.
Only US diesel?? 03 93 Cosmic Blue
Also Black 06 93 Combi, White 89 900TCV
gjdavies's Avatar
Originally Posted by ctrlz View Post
Ooooo, good answer!
**** hot me!!
Had enough of these cars now, feel like I know them inside out. Can't believe i'm on my 4th 9-3!!!
Old 4th February 2012
krisp krisp is offline
My Saabs: 2006 9-3 2.0T 5MT JZW Stg1
Where does one get a replacement steering angle sensor? Dealership says complete CIM required to fix faulty steering angle sensor.
katanamaster katanamaster is offline
My Saabs: 2003 9-3 Linear
Garage
Whenever I make a slow right turn, I get the same 'Stability Malfunction' warning, so if anyone has the answer to this, I would also be greatly appreciative of the knowledge as well.
Old 17th January 2013
Jaco2k's Avatar
Jaco2k Jaco2k is offline
My Saabs: Skoda Octavia vRS TSi MY15 6MT
Getting the exact same thing - also the same C0460 error and also on the slow right turn.
I would like to avoid replacing the CIM so... if there is a component to be replaced that can spare the CIM, I am all ears!
Post # 162129 is the best to see the innards of a CIM. Great job to anzollo and steen for the photos. Windshield wiper and turn switches as well as clockspring and steering angle sensors can be replaced without resorting to a new CIM. Its fairly easy...but clocksprings and steering angle sensors may require recalibration with Tech 2, but no security access/TIS is needed.
Old 22nd January 2013
Garage
How is your front end alignment? I've noticed that whenever I get my front end aligned, these messages never pop up. But as soon as I start hitting all the god forsaken potholes that Illinois has, the front end gets jacked up. Then thats when my car starts throwing the errors. I've just come to live with it.
Old 23rd January 2013
Jaco2k's Avatar
First thing I did was take it to align. As soon as I saw the first machine read turn up all green I knew that $$$$ will be spent
Rulling the alignment out, although the rear left was a bit out, it seems to have helped but not solved. Also my winter tires are shot so... since I need to buy new tires anyway, will see if it somehow helps.
Problem is that I have the yearly inspection coming and if that error pops up during it, it is an automatic fail :P
Old 10th December 2014
kakeya kakeya is offline
New Member
My Saabs: 2011 saab 9-4x
Default Opcom
I got my op-com 2010V from diyobd2.fr €17.00 only,came to my door a week later after i ordered,
Old 21st June 2015
colocoter colocoter is offline
My Saabs: 2006 93 COMBI
Cool finally i fixed the problem
Identifier: 0x0301
Alpha code: AA
(11) - Not present
Cheers
finally after few month i fix the angle sensor just i bud an use CIM from 2003 saab 93 sedan and i opened taking out the angle sensor and i replaced with my car angle sensor
sorry my writing is not good just i live the pic on the topic Click image for larger version
no more Stability Control Failure
Old 21st June 2015
Diggs's Avatar
Diggs Diggs is online now
My Saabs: 2003 9³SS Linear; 2015 VW GTI
Question
was it a straight swap or did you need a tech2?
The answer is almost always....Tech2
Old 21st June 2015
Hi there you need tech to for calibration the angle sensor and clear DTC fult code by tech 2 I working care fully on the car take long time but I Don
Old 10th October 2016
dougstrach dougstrach is offline
I thought I would share my Stability Control Failure story as well as my steering angle sensor fix that resolved it.
Issue: At first intermittently, but then consistently, my 2006 9-3 Aero Sportcombi would give me a Stability Control Failure message within the first minute or so of my drive, usually cornering slowly in the parking lot--steering both to the left and right. No errors at start-up, only when I was driving.
Process: I took it to the garage shop Indianapolis Saab mechanic and they hadn't seen this issue yet and weren't sure where to start other than clearing the codes and calibrating the sensor. Neither worked. Issue still there.
Fix: I followed the instructions of replacing the steering angle sensor within the CIM by buying a used CIM off of eBay for my donor. Pretty easy fix, just be careful with the long pins when reassembling otherwise your airbag will give you another warning. Once reassembled, the vehicle gives the Stability Control Failure message at start-up. This let me know something was different. Another trip to the guy with the Tech2 and they cleared the codes, re-calibrated my new sensor and VIOLA! No more errors.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Fault code advice - P0705p0705 transmission range sensor circuit malfunction Florida Saab Girl NG900 & OG9-3 Workshop 9 24th December 2013 09:51 PM
Steering Angle Sensor 51-HOTaero 9-5 Workshop 7 31st May 2009 03:12 PM
Fault code advice - P0705p0705 transmission range sensor circuit malfunction Florida Saab Girl NG900 & OG9-3 Workshop 1 23rd December 2008 04:05 PM
o2 sensor heater circuit malfunction turbojohnny NG900 & OG9-3 Workshop 9 4th June 2008 10:16 PM
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) Slaab4life NG900 & OG9-3 Workshop 3 21st February 2005 07:45 AM
