Good News for rough running cold starts - SaabCentral Forums
Old 17th December 2010
photousa's Avatar
photousa photousa is offline
My Saabs: 2003 Saab 9-5 Aero Wagon 2.3T HO Manual
Default Good News for rough running cold starts ***With Videos***
Someone posted the other day, that all we do here is post problems about Saabs, so here's a little good news. I was having cold start, rough running issues. The car was running so rough on cold startups, it was throwing a P0340 code. After a couple of minutes, the problem would clear up and the engine would return to running smoothly. Here's video #1 showing the cold start, it's east to see the bad vibrations I'm talking about: http://www.youtube.com/watch?v=B4ya7szSIV0. If I'm correct, P0340 points to the DIC or plugs. I couldn't believe my DIC would be bad with only 11,150 miles and 1.6 years on it. On a whim, I decided to add a couple of bottles of the product, "Heet", in the yellow bottle over the course of a couple of days. To my amazement, the very next day, all of my rough running, cold start issues disspeared, along with my trouble code, here's the second video: http://www.youtube.com/watch?v=UuvDc..._order&list=UL My battery tested bad for 875 CCA, which is why it sounds like it's on it's last leg, but at least the rough running starts have been solved. I must bought some watery gas somewhere along the line.
2003 Saab 9-5 Aero Sport Wagon >>> My other home:
2.3T HO B235R Manual 157,000 miles
My Saab Mechanic in Chicago: George @ G&S (773) 637-8431
shaggy shaggy is offline
My Saabs: '08 Edna, cosmic blue on parchment
[/QUOTE]
did your problems start after buying fuel from a particular vendor or were they happening over multiple tankfulls?
zoli.m13's Avatar
zoli.m13 zoli.m13 is offline
My Saabs: MY98 9-5 B205E SE M/T
Garage
Question
Originally Posted by photousa View Post
... Here's video #1 showing the cold start, it's east to see the bad vibrations I'm talking about: http://www.youtube.com/watch?v=B4ya7szSIV0. ...
Hi photousa,
I saw some pretty nice insulation on the air intake tube / intake manifold - am I right? Is it useful?
photousa's Avatar
Originally Posted by zoli.m13 View Post
Hi photousa,
I think the plastic snorkel / intake just looks like insulation, it's all stock, nothing is wrapped around it. I have a broken clip on my engine cover, so it bounces around quite a bit.
zoli.m13's Avatar
Garage
...I have a broken clip on my engine cover, so it bounces around quite a bit.
Me too...
photousa's Avatar
did your problems start after buying fuel from a particular vendor or were they happening over multiple tankfulls?[/QUOTE]
Now that you mention it, the problem just showed up overnight, so it could probably be traced to an individual vendor. I usually stick to reputable vendors like BP or Shell and only buy 93 Octane. I'll have to look at my receipts. Before the rough idle issue, I've always thought the car cranked too long before firing, so recently I bought a new supply line check valve which I've yet to install, my Dad was saying my problem could also be my Negative battery cable.
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
I make it a habit to add dry gas to the tank every winter to avoid cold start problems. Been doing it for years condensation happens when the fuel levels remain low in the fuel tank HEET is good; my choice is dry gas.
david bartlett david bartlett is offline
My Saabs: 2001 9-3, 2004 9-5 Aero
Gasoline in my area of the world already has 10% Ethanol added to it during the Winter months, so adding more would not be needed.
Keeping the tank mostly full will help.
"I don't fully understand everything I know!"
Old 18th December 2010
J-Rod's Avatar
J-Rod J-Rod is offline
My Saabs: 2003 9-5 ARC, 2000 9-5 SC Aero Clone
Garage
Slightly off topic, but looking for a quick answer...
Is it better to run 89 octane gas in the cold than 93?
I used 93 all summer, and I remember reading on here somewhere that 89 is better in winter.
ski ski is offline
My Saabs: 02 95 aero
i don;t think it's better, just you wont notice the difference as much between 93 and 89 in the winter as the cold air that your engine is sucking in allows for less of a chance of pre-ignition (knocking) which in turn causes t7 to cut back the power
Old 20th October 2015
iitsrayy iitsrayy is offline
My Saabs: 2001 SAAB 9-5
Default Videos are private now
Could you make the videos public again? I am experiencing the same problems and wanted to take a look at your video but they were private? I would really appreciate it..
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Anyone else have rough running/stall-out issues after warm starts? prewittj1 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 68 27th April 2010 02:41 PM
Rough Engine Idle on Cold Starts BF2009 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 3 26th September 2009 02:12 PM
New suspension noise after thrust supports replaced and rough cold-starts... CMerriman 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 9 26th February 2008 09:15 PM
Rough cold weather running AeroMax NG900 & OG9-3 Workshop 4 27th December 2004 11:01 AM
rough running esp slow cold idle - CIS K-Jet 1989 900i jim galbraith C900 Workshop 10 10th September 2003 03:48 PM
