02 9-3 Stalling issue. - SaabCentral Forums
Old 12th December 2010
soviet911 soviet911 is offline
Default 02 9-3 Stalling issue.
My mothers 9-3 is having an issue where upon slowing down or breaking the car will stall and acording to her it has uneven idle while at a stop. Thats the only clues I have, what are some things to check to see what could be the problem? I wont have a chance till monday to look at the car but want to prepare.
Few things I think could be a problem
-vacume leak.
-failing fuel pump
-fuel filter in need of replacement.
-bad fuel (she is going to fill up her car tommorow with fuel from different station, 91 only.)
Any and all thoughts will be appreciated. thanks.
It is a 2002 9-3 SE automatic.
earthworm's Avatar
Saab Sage!
"Vacuum leaks" are part of the maintenance, as is the filter(change every 100K miles or so.).
The stalling could well be caused by the throttle body control, these are troublesome.
If the fuel pump were failing, logically the volume delivered at WOT would be insufficient.
The earthworm
'96 900S, Automatic
woodyg's Avatar
woodyg woodyg is offline
Location: (Boston, MA) 1998, 900S, 4 Door, 2.3 non-turbo,(Shell Rotella T6) dist igntion,
My Saabs: 112k, 5 spd(MTF-0063), No ACC, Moonroof
Garage
adding to earthwarms thoguhts....when ever I here Idle issues the first things I do are ......clean the Idle air control valve(not sure if you have one) , the throttle body and the MAF sensor.......
2.3 non-turbo(Rotella T6 5W-40), Distributor Ignition.(No DIC),NGK BCPPR6EGP plugs, 5 speed(awaiting MFL-0063 for flush and refill). recnet coolant flush(yellow) powersteering=CHF-11S, No ACC. working on bringing the maintenance up to par
I replaced spark plugs and air filter about 3-4 month ago and that was probably less then 2000 miles. But I will check the condition of the air filter once I get there as well as look for any vacume leaks (that wont be fun ).
Im pretty sure there is no IAC as it is a T7 and as far as I read idle is done with throttle body. Time to clean it out I guess as well as MAF. Any good websites that show how to clean those out? Thanks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Stalling Issue in '87 900s scriabin C900 Workshop 1 1st July 2010 08:09 PM
Stalling issue please help. 89'16vSPG C900 Workshop 5 12th June 2010 05:03 PM
Stalling Issue justin.graeff 9000 Workshop 8 9th October 2008 01:10 PM
Another stalling issue LiQuiD7ePheN 9-5 Workshop 3 8th March 2006 04:47 PM
Stalling Issue Bmaione C900 Workshop 1 9th August 2003 12:33 PM
