Re-enable Fog lights after replacing the car battery due to battery drain. - SaabCentral Forums
Old 03-12-10
seanroh seanroh is offline
New Member
My Saabs: 2004 9-4 Aero
Default Re-enable Fog lights after replacing the car battery due to battery drain.
Hello,
I had a car parked for a while with my music on, which drained my battery. Unfortunately, Saab does not allow jump start unless you find a fuse that controls the battery monitoring or something.
However, I've called AAA and got my battery replaced, but now my fog lights, both front and rear, doesn't work at all. I don't get any error messages and the lights have been replaced very recently.
It seems like there I need to reprogram or reset my car to "understand" it is equipped with fog lights, but I don't know how.
I've accidentally figured out how to re-enable auto windows up/down feature by holding the windows up switch for a while until I hear a "beep" sound (the same sound you hear inputting a new seat position to the memory seat).
Please help how I can reset the car and get my fog lights to work again.
Thank you!!
Old 03-12-10
loochy's Avatar
loochy loochy is offline
My Saabs: 2007 9-3 2.0T, BSR Stage 3, Polar White
Garage
Really? I've jump started my car several times without problem
Old 03-12-10
New Member
When the battery is completely drained on Saab's (I've got to this point trying to squeeze out the power left in the battery to start the car), you will get a message on your information display, which I forgot what it was.
After you reach that point, the battery assumes that it is baring a risk of having a dead cell, which can turn into an explosive when used.
So, the AAA battery guy had to replace the battery because the jump start won't work.
However, until you get the battery notification message on your info display, I think you can still jump start. I've also had a success with push start.
BTW, it is 2004 Saab 9-3 Aero I have.
Similar Threads
Battery Drain help nikoswave Saab 9-3 & NG900 Workshop 32 16-06-11 06:14 PM
Battery drain KRUBEGH Saab 9000 Workshop 0 19-08-08 12:58 PM
Battery Drain philjohnhb Classic Saab 900 Workshop 3 10-12-07 11:40 AM
Battery drain Husky570 Classic Saab 900 Workshop 2 05-09-06 09:29 PM
Battery Drain cassonian Saab 9000 Workshop 5 09-12-05 07:46 AM
