| Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900 |
I have a 93 volvo 245(station wagon).Its rwd, and everything on it is built like a tank,and its weight distribution is really close to 50/50(it really is).
BUT it has a very anemic engine.Stock is 114 hp from a 2.3L with fuel injection. So Im looking into an engine swap.I was looking at some V6's to get about 200 hp or so,stuff like the GM 3100,GM 3.8,ford 3.0,etc.Then I thought none of those engines would be as strong or as durable as whats in there now.So I would do the swap then have to rebuild the motor pretty soon depending on how many miles were on the donor vehicle. So then I thought why not a SAAB B series engine.175HP stock,16V,and legendary durability. In the UK there are possible connections with opel and triumph.However those vehicles don't exist here.So I was wondering what if anything USA saab owners who have hooked a Saab engine to a RWD transmission did. granted a volvo station wagon might not be the best canidate for a swap,but it has some good things going for it: 50/50 weight balance 4 link solid axle factory and VERY DURABLE PARTS so it would be like a practicable,durable rx7 or beemer...
SAAB: Its an Addiction |
| Sponsored Links | ||
Advertisement | ||
I'd go with a B203 instead of a 202, but either should work I'd think. You could pull one from a 9000 and it will even have an oil pan. I suppose that just like any other engine swap, you'll have to deal with installing engine management, various hoses that don't match the original, adapt the motor mounts and then make an adapter to the tranny. It may just be easier and faster to look at turbocharging the 2.3l Volvo engine if it's built well. You may get very similar results to the B engine. Either way you will be in for a project.
There's plenty of turbo charged 240's on the net... Try the Volvo forums
G
"we can allow satellites, planets, suns, universe, nay whole systems of universe[s,] to be governed by laws, but the smallest insect, we wish to be created at once by special act" - Charles Darwin http://www.nicecupofteaandasitdown.com/ http://www.saabcentral.com/phpgallery/Gs-little-Saab |
Sounds like a good Ford 302 swap. Add in a T5 and life will be good.
I've often wondered why people don't use the B204 or B234 (9000 version of B202 but with balance shafts and increased to 2.3L) as retrofits for more cars. They're incredibly smooth, durable, powerful, and efficient. And with Trionic 5, you can have a superb grip on your engine's management software! I think Americans are scared of them because they are somewhat advanced designs. As for putting anything American and iron...you know what I think <points down to sig>. I've been thinking about the suitability of a B234 turbo or N/A in a Citroën DS, to replace the anemic and inefficient variety of 1.9-2.3 pushrod engines they were available with, but I think I'd need a transaxle from a Porsche to take the extra power and torque.
You'll need to make an adapter plate. And you'll need to see where the optimal break between Volvo and SAAB parts is. You could use a SAAB clutch, or just get SAAB flywheel drilled out for Volvo clutch. Or (maybe I'm dreaming, but it would be nice) the Volvo disc will fit behind a SAAB pressure plate, with no modifications. Chances are, you're going to need to at least cut some splines or drill some holes to get everything to line up and take power through. Speaking of which, as long as you're making an adapter plate, are you totally satisfied with the Volvo gearbox? As long as you're going through the trouble to make an adapter plate, why not look at your gearbox options as well? Better highway revs wouldn't be the least thing you'd gain.
My buddy was putting a B234 into an Audi. He built his own adapter plate out of 1/2" aluminum. The Audi clutch disc fit perfectly into the Saab pressure plate.
I'd be willing to bet you'd need a custom input shaft made for the Volvo gearbox.
*SAABCentral NEW ENGLAND CREW Member 008* (now in NC) T5Suite2.0 Stage 3+, Full DIY 3" exhaust w/Magnaflow, Spec stage 2+ clutch, "Custom" airbox mod, Forge BPV, DIY strut brace, Poly bushings, various powder-coated goodies |
the gearbox that is in a volvo is a RWD version of a C900 transmission except that its made out of marble rather than glass.
Im not looking to turbo charge the existing engine because even at 5 PSI it needs premium to avoid knocking under normal use. The top of the line STOCK volvo turbo engine only comes with 160 hp for that car unless I go with a newer motor which is a major PITA to in install. not installing a V8.I like being able to turn so handling balance is important to me.not to mention the gas mileage is the suckage.
mileage nonewithstanding, you'd be suprised how light an all aluminum small block is - only maybe 50-100 pounds heavier at most fully dressed compared to an all iron I4 like the B202...
Though I must admit the idea of a B202 mated to a bulletproof rear-wheel dive tranny does sound very appealing. Imho theres a lot of potential power there, thats not really been realized due to transmission limitations. |
On a side note, I wonder how well those engines, in B234 trim, would work with trionic. Quote:
I too would not put a V8 because it is just too commonplace. Like, a lot of people think the only way to get *true* power is a carbed SBC with perhaps a supercharger or two. And 2sp powerglide. And rear solid axle with drum brakes. In fact, I am surprised nobody did that to a Saab.
My adventures with this convertible.
i am inspired. i will replace my windshield... with an intercooler. swedishK |
PS :drool: |
Why buy a Saab then?
Volvo units are stout. You can't tell me that rengineering the wheel is easier than changing the wheel bearing.
www.turbobricks.com done. |
My comment was about putting a V8 in it. If you want a SBC, get a chevy wrapped around it.
couple of questions:
does a B234 out of a 9k have a steel oil pan? I heard that the B234 has a "gm pattern? is that Metric gm?
But this is a Volvo an SBC swap is just so easy and worthwhile!
Just do the V8, the day a Volvo with a small block is commonplace is the day I eat my hat! But it is also much easier, this lemons team built a v8olvo for under $500!
24hrs of LeMons SAAB 900 project: The Carbeque Updated 5/20/13 Hahaha we got featured in an article at Forbes.com. SAAB love. |
Which is why I love the 68 Camaro with a 5.0L Ford engine in it.
I like the V8 idea. How about an LS1+T56 swap? get an LS1 out of a 98-02 f-body or corvette and a matching T56 6 speed manual. run it carbed, do all necessary fabrication, and go destroy some ricers.
Ugh geez come on I had to come look at this as suggested by another member. How misinformed are you about Volvo motors that you would even think about doing something like what you are thinking.
You can get almost 200hp out of your stock engine any day of the week by merely doing a +T at the cost of maybe 300 dollars. You can easily run 8psi all day long on crappy gas or 13psi on the good stuff. You can achieve 300hp with not to much drama. Before i dismantled mine i was running 17lbs with no issues. It was I don't know how many hp but it moved pretty damn good. 0-60 run while trying to maintain grip on a crappy road. http://smg.photobucket.com/albums/v2..._VIDEO_010.mp4 It was also during a time when the car was running no where near its fastest. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| New 9-5 Wagon headed Stateside | WhiteT5 | Saab Corporate News | 0 | 28-07-10 02:04 PM |
| Spotted: 9-3SS TiD stateside | PoisonBeef | The Lounge | 4 | 22-02-10 12:56 AM |
| stateside 900 turbos running e85 | Hayes | Classic Saab 900 Workshop | 14 | 04-06-08 09:01 AM |
| 9000 b202 to 900 b202? | FRANKINAUS | Classic Saab 900 Workshop | 1 | 05-03-05 11:14 AM |
| anyone else get the safety recall for the NG900 stateside? | CaptBrandini | The Lounge | 13 | 29-12-04 12:22 PM |
