2002 95 water pump change - SaabCentral Forums
Old 1st December 2010
spg1 spg1 is offline
My Saabs: 2008 Aero 95
Default 2002 95 water pump change
I have googled and search but didn't find anything. Is there some instruction and things to look out for when doing the job. If anyone has done this job, how long did it take?
It is getting pretty cold here and I have to do it outside.
One more thing, the water pump comes with the one gasket that is behind it but there are some other gaskets and "O" rings that are shown behind it. Is it necessary to change them as well or is it fine for just the water pump gasket alone?
photousa's Avatar
photousa photousa is offline
My Saabs: 2003 Saab 9-5 Aero Wagon 2.3T HO Manual
Here's a link that might help: http://www.scribd.com/doc/23134799/Water-Pump-Replacement#fullscreenn
If you send me a PM with your email, I will send you my copy of the WIS water pump instructions. I have not replaced my water pump yet, it's just another project in the que.
2003 Saab 9-5 Aero Sport Wagon >>> My other home:
2.3T HO B235R Manual 157,000 miles
My Saab Mechanic in Chicago: George @ G&S (773) 637-8431
Old 3rd December 2010
duramax2002 duramax2002 is offline
My Saabs: 2000 9-5 Aero
I changed mine about a month ago and it took all day. I did have more to do than just water pump. The pump bearings went out on the old pump and the pulley cut into the timing chain cover and i had to drain the oil and clean good and jb weld the groves. I also had an issue when I took the pipe that leaves the water pump and goes to the turbo loose. One of the copper washer seals (there are two) was cracked and I tried to reuse(dumb) but I did not have one? Ended up going to local NAPA and just looking through everything they had until I found one close and filed to fit. They are cheap and you should order with the pump when you get it.
Thanks for all the help. I helped my son do the job and it took about 6 hours. The only thing that was a bit of a problem was the screws holding the casing together. Only one snapped and I had to find another bolt. Good job though,
Thanks.
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
It's a long but easy job. Lots of stuff to remove and replace but nothing too horrible to access. 6 hrs is about right.
photousa's Avatar
Thanks.
Good deal, glad that worked out. I'm glad duramax2002 gave us a heads up about the two copper washers that could possibly be damaged, I'll add those to my shopping list. Did you every get any opinions on whether to use any sealant on the water pump gasket?
Old 4th December 2010
I didn't use any sealant.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Leak around water pump. Replace pump or gaskets/rings? flyhop NG900 & OG9-3 Workshop 2 16th November 2010 10:24 AM
2002 saab 9-3 Water pump change saabsal NG900 & OG9-3 Workshop 0 3rd November 2010 03:41 PM
water pump change.. Aydensaab 9-5 Workshop 0 12th December 2007 01:43 AM
Water pump change... TooMany2cvs C900 Workshop 19 26th October 2007 05:29 AM
WATER PUMP CHANGE - HOW DIFFICULT? dafyddtomos@ic24.net C900 Workshop 2 6th February 2002 11:00 PM
