Removing door panel - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 29th November 2010
ShawnJ ShawnJ is offline
My Saabs: 1997 9000CSE
Default Removing door panel
I am trying to resolve intermittent exterior door handle issues on my 97 9000CSE. I have all bolts out, but the instructions I have say to remove the mirror switch cover (done) and then remove the switch...how?
I have scratched the heck out of the handle trim trying to get the stupid thing out! Are there pins, clips...how does the mirror switch come out?
Superaero Superaero is offline
My Saabs: 1997 Aero manual
Ah, yes, the secret lever.
I believe all 9000 door panels with this electric mirror feature are the same from the inception of the car until the final model.
I say this because I only have the 1986-88 shop manual and I have not removed the driver's door panel for a long time. So, if what I describe does not work wait for someone with a newer 9000 to answer this thread with the revised procedure, if there is one.
The mirror selector switch button itself must come off first, it pulls off the mirror selector switch itself (this is NOT the joystick adjuster switch but the flat semi circular button that selects either right or left mirror or neutral, i.e. neither mirror).
Then the shop manual says to "insert a screwdriver and lever the catch forward". The picture shows the screwdriver being inserted into the slot left when the mirror selector switch has been removed.
Behind this will be the pesky screw that is preventing you from removing the surround around the interior door handle and thus preventing you from removing the door panel.
Old 30th November 2010
mechanicandy mechanicandy is offline
Location: 18 parkvale longside peterhead aberdeenshire ab424xw
My Saabs: 98 2.0 9000 anniversarie
Ive a 98 cse two weeks ago tried to take my trim off to fix lock broke switch and handle surround there are two clips on switch try a small knife either at left or right i got two spare ones when you get both out just put surround back without screw and clip in switch when you remove switch and screw prise out surround from bottom part as there are two lugs at top
bc109 bc109 is offline
My Saabs: 9000 2.3CSE;9000 2.0CD
Default driver door latch cover
Superaero is right. Saab 9000 cse 1997. Pull off left/right selector knob for the door mirror adjusters... ( on the up and down switch ! ).
Remove small foam padding.
Insert thin screwdriver to release the large retaining clip, hidden by the two items above.
Tags
9000, door panel, mirror
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Removing door panel inserts everyshadeofblue 9-5 Workshop 3 27th February 2009 05:09 PM
Removing door and quarter panel trim longjon76 NG900 & OG9-3 Performance, Mods & Tuning 7 14th June 2007 11:58 AM
Removing Front Door Panel Eurospeed 9-5 Workshop 2 6th May 2007 06:46 PM
Removing door panel (2005 linear) DMBeer41 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 10 5th October 2006 12:54 PM
Removing door panel? gotpiranha? 9000 Workshop 3 17th August 2006 11:12 PM
