| Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900 |
I've got a quote for some custom type 8 primaries and hope to get a group buy situation put together. These would be completely made from scratch with the proper splines for the factory shafts, upper and lower, and would have the proper upper bearing cavity along with the circlip/retainer ring slots in the upper gear. The holes for drifting in the lower nut will also be present.
I was quoted $600/set for a series of 10 sets, possibly less if there are more. Also, the price could be less if the gearshop has the proper broach for the splines in stock already (he needs me to bring the shafts in to know for sure). The teeth would be the same as factory, however they would be straight cut rather than helical cut from row to row. I'm still waiting to hear how much more a helical cut (as the factory sprockets are) would cost, but the shop is capable of doing it. At $600/set, we could also have 4 rows of teeth, though I'm not sure that it's necessary nor easy to fit in the case. That would also require modification to the tensioner, so we'll probably be sticking with 3 rows unless there's some outcry about it. How many would be interested? What further information would you like to have? As it sits right now, 4-6 more sets spoken for would probably be enough to meet the 10 set minimum. If we can get it to 20, we may see the price go down. Given that a used set will usually get this much, even $600 seems pretty reasonable to me. The gearshop is called Custom Gear, Inc. here in Seattle and was highly recommended to me by The Gear Works (also in Seattle). The work I've seen in the shop appears to be all very high quality. I do a little machine work myself, so I don't say that without a little knowledge about what I'm looking at. |
| Sponsored Links | ||
Advertisement | ||
t9s, maybe? (Is there enough space in the primary housing?) or t8.5s, with the lower sprocket smaller but the same upper and a shorter chain?
Adrian Soon to be living life on the road in an old VW http://WhereverTheRoadGoes.com |
What kind of chains would be used with these sprockets?
"It's there to remind our lads who they're playing for, and to remind the opposition who they're playing against." Bill Shankly about the 'This is Anfield' plaque |
The factory original chains would be used, same tooth spacing and same number of links overall.
That could be OK, old chains on new sprockets? It would be good to have new chains.
Those're available, at least in North America. For international buyers, mmoe, are you planning on sending chains with the gears? A bulk order from eeuro wouldn't be at all painful.
Chains can be bought direct from Iwis for not a bad price at all.
Photo Gallery |
I think I'll let people take care of the chains themselves. Some may not wish to put new chains on, other will. I think the best price I've seen on chains is about $18 ea, so figure about $50 for 3 chains if you want new. euromobile's suggestion is not a bad one either regarding eeuro.
Old chains can be checked for wear as per the Saab factory manuals by measuring the distance from the tensioner to the sidewall of the primary case. That measurement should not be under 10mm if my memory serves. So long as the measurement is greater than the specified minimum, the chain has not stretched enough to warrant replacement. However, the chains will have worn slightly with the sprockets and the safe bet would be new chains. |
Another option would be a custom ring/pinion which could provide a type 8 revolutions equivalent with type 6 primaries, which would further allow type 9 revs to be produced with type 7 primaries. However, that would require a rebuild to put into service and it may apply more stress than the somewhat undersized gears could handle. |
Hasn't this been covered before....http://www.saabcentral.com/forums/sh...type+primaries. That said I have type 8's and I might be interested in a second set at the right price.
In the other thread, no one even found a source that could build them. The gearshop I've found is not only capable, but willing to provide whatever we ask. If we decide we all would prefer the helical cut, it will be a bit more. If we decide we're OK with the straight cut, then this is the estimate given to me. If we wanted a 4th row of teeth, it would be approx. an extra $20/sprocket. The one thing I need to verify is whether or not the gears were spec'd at the 62C rockwell hardness that the originals are. He gave me a specified material, but I don't recall asking what it's native hardness is. I'll also look into what cryo-treating these would cost. IMHO, if the metal is at least 56C, they would probably be fine without treatment, but I will work on getting that spec from the shop. It should be noted that these are absolutely 100% custom sprockets made from a blank. There would be no use of catalog parts or anything like that. The teeth will be cut to spec, the splines will be cut to spec, the bearing pocket will be cut to spec, the bearing retainer circlip slot will be cut to spec and the clutch shaft retaining ring slot will be cut to spec. All of these specs will match the factory specs for the type 7s, only with more/less teeth where appropriate. The area surrounding the front input shaft bearing will be beefed up as much as possible to provide support to the rear row of teeth, without interfering with the bearing/housing. The holes for the factory input shaft nut drifts will be provided. These will be as close to the factory originals as possible within what I believe to be a reasonable budget. |
I'd be in if I didn't already have a set! Unfortunately (fortunately?) I just got my grubby hands on some real SAAB ones.
If it means anything to anybody, I've found another part number for the top sprocket bearing, so you won't have to pay through the nose for that either. Same thing as is used in Jeep axles, and sold by SKF: SAAB # 8710865 Timken #s U298 and U261L (cup and cone respectively) OR U298-90011 (unit part number) SKF # 331579B Asking a NAPA auto parts store in the USA for a BR9 (or searching on the Napa site for it) will also get you this bearing, probably an SKF 331579B, and at a rate much cheaper than what eEuroparts or the Saabsite charges. RockAuto also uses the SKF BR9 part number but I haven't actually seen one of those. It comes with a compression sleeve for use in a rear axle, but this is a separate part and means nothing to us (would make a good paperweight). They also go in rear axles of certain American cars (jeep ZJ with 44 or 35 rear axle to name one), as well as in some John Deere implement. FWIW.
Count me in for a set. Thanks. what would be the lead time for the order? I am in NYC USA.
Lead time is 6-8 weeks from the point where there is enough people to put the order together. There will have to be some sort of deposit I'm sure, so I'll check on what the shop wants for a deposit as well.
At this point, we have:
1: Myself - 1 or 2 sets (depending on interest level by others) 2: glorydaze - 1 set 3: 900 aero - 1 set (I presume you are also the same 900aero form SL.net?) 4: anonymous (to you, not to me 5: doing-it-the-hard-way - 1 set (from SL.net) dan-the-kid - maybe? (from SL.net) dmgb5 - maybe? So at this point were looking at 5-6 sets that would be spoken for, but needing 4-5 more with 2 maybes. Would it make a difference to people if I paid extra for a proof of concept (prototype)? If so, it would increase the price to each buyer as I would spread that cost over the following sets, but the benefit would be that you have something to see prior to purchase. The cost would probably escalate by around $100-$150/set for 10 sets though ($50-$100 over 20, etc., etc.), so it would be a significant additional cost. |
I would say as long as the shop grants that the gears will fit and work/ not fail or money back we should be fine.
I might have a friend or 2 interested in those gears too. but what does every one feel about making the lower set 23 teeth instead of 24. this way we can have a 8.5 gear set instead a #8.. Just a thought. I am guessing that making the lower ones smaller shouldn't cause a fitting problem as long as the tensioner would make the slack without issues.
The only way to accommodate this modification is to move the teeth forward on both upper and lower primaries. Then you would have to make a new (taller) tensioner housing or the outer chain would not ride on the guide. Even then it is unknown whether or not there is enough clearance in the case or if the increased leverage on the input shaft bearings would cause premature bearing failure since the inner-most chain would be applying force further from the bearing than normal.In my opinion, it is just not practical. |
What exactly are the benefits of type 8 primaries?
I assume lower RPMs at high speed. Is this the only benefit? Cheers. |
correct = higher top speed. 28mph per 1000 rpm in 5th gear. so depending on your tune, your set up and power. In theory you should be able to hit 168mph
also you should be able to hit 60 mph in 2 gear. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
