Changed my transmission! - SaabCentral Forums
Old 25-12-03
DeLorean DeLorean is offline
Default Changed my transmission!
Well I had had just about enough of the SPG's transmission's bearing noise & shaky gear change, so I replaced it. Should be good now for full power on the next saab meet Check out a few pics! Overall, it went well. It did not take too much time either. Replaced the clutch, engine mounts, brakes (pads and discs), all fluids, driver side axle shaft and bearing, and some other odds and ends while I was at it. It's still not 100% finished, but I expect to be finished with everything tomorrow.
Old 26-12-03
tandino tandino is offline
Congratulations Jeff,
Thats a scene ive seen far too many times myself
Pete.
Old 26-12-03
pda's Avatar
pda pda is offline
My Saabs: T8, FMIC,173bhp & 228ft lb
Hi Jeff,
nice number plate "SPG 900"
hope all goes well with your new gearbox :wink: :wink:
cheers Paul
Old 26-12-03
TheRedRocket TheRedRocket is offline
Good Job! Jeff, your a inspiration to all us DIY'S!
Old 27-12-03
Thanks everyone. After swaping my driver side hub bearing (again ) Everything is working great. The new trans shifts very well and feels GREAT. It's like a totaly different car Overall it's not that hard of a DYI job, but be prepared for quite a few cuts and scrapes along the way. I'm trying to keep the wheel spin in 1st and 2nd to a minimum this time , hopefuly I can get a good bit of mileage out of this transmission. It's soooo nice puting it into 5th and not having that WAAAAAAAAAAAAAAA sound
Old 28-12-03
fura fura is offline
Yeah, you are lucky And I have those WAAAAA sounds in 5th, 3d and even 4th gears ops:
Old 28-12-03
saabstar saabstar is offline
one question where did you hook up the engine lift to pick up the ening out of the car. i want to do this but i would thing i would put to much pressure on the head more like the head gasket, when it is lifted.
Old 28-12-03
Hooked my home made lift to the engine lifting points, one on the front (bolted to the head) one is an old 2.1 AC bracket that I can hook things to. Hooked those with chains to my engine balance then to my chain drive lift. That's the way to lift it, really the only way... Don't worry, it's not going to hurt anything.
Old 28-12-03
tevid's Avatar
tevid tevid is offline
why'd you yank the oil filter housing
Old 28-12-03
removed clutch cause I was changing that too (as I already said), Oil filter housing because the cooler lines were stuck, and the housing is only bolted on with 3 bolts. Why waste 20 min's trying to get those lines off when un-bolting the entire housing takes 2 min? I also had a new gasket (about $1.00) so there was no reason not to. And, yes I had the proper tools for the cooler lines, even with those there was high risk of me stripping them out with the amount of force I was putting on them. They were not going to come off w/o a major fight.
Old 28-12-03
During my previous 3 engine/transmission swaps i removed the oil filter housing - saves alot of time and as Jeff has meniotned the oil cooler lines are alot more expensive than a cheap gasket...
Pete.
Old 28-12-03
tevid's Avatar
guess i must be lucky mine come out with no troubles whatsoever
Old 30-12-03
GB24Hours's Avatar
GB24Hours GB24Hours is offline
My Saabs: 1990 900 Turbo SPG; 2002 9-3 SE 5dr
Nice job Jeff.
On one hand I envy you guys with the know-how to do this kind of stuff..... and on the other I'm glad I don't (or CAN'T) work THAT much on my car.
Costs me more $$$, though.
Old 31-12-03
4saabstoomany's Avatar
4saabstoomany 4saabstoomany is offline
My Saabs: 86 900T
i'de love tolearn how to do that... I love working on my car.. someday when i get out of college.. and have a lot more time.. i'll start working in deep engine i hope!
