code P0300 03' 9-3 - SaabCentral Forums
Old 27th October 2010
digimurda digimurda is offline
New Member
My Saabs: 2003 saab 93
Unhappy code P0300 03' 9-3
hi, i have a 2003 sab 9-3
i have my check engine light on and the code is p0300 (random misfire)
the car runs fine but when i step on the gas a little hard it shakes and studers, i've noticed it dies this when the turbo gauge needle is almost on the red part.
if it's the coils, how can i tell wich one is bad? or what is wrong?
please help, thanks.
pacotaco's Avatar
pacotaco pacotaco is offline
My Saabs: 04 93 arc espresso black
well it sure seems like an ignition issue the easiest way to find out is to buy one new one and replace them one after the other till the issue is gone. you also might be able to look at the coil itself and you might see a spider web crack like this it should also be on the rubber piece of the coil too, i believe this can show that the coil is blown both of mine had that crack on them
i <3 backroads.
i rule your internet.
aerojon's Avatar
aerojon aerojon is offline
Check for vacuum leaks.split pipes & alike..
Is still running factory oe coils with Hirsch tune..
Kooby Kooby is offline
My Saabs: 2004 9³ Aero 6MT
Depending on the mileage of your car, you may want to replace all 4. They're approx $75 at rockauto and a very easy DIY repair. I bought 2 initially and did the dance of swapping them out. Found the shudder was gone but due to the age of the other coils, I was not getting full power, especially above 4K rpm. When I replaced all 4, all is good.
Hope this helps.
2004 9³ Aero 6MT
BSR Stage 1
Megan Springs
Old 25th February 2013
death shot death shot is offline
My Saabs: 2007 Saab 9-3 2.0T
2007 9-3 2.0T:
I thought I'd revive this thread as I'm having an issue with the same CEL code (p0300 with the occasional p0304). I've been having this issue where my car struggles to start (this morning it would not) when I try to cold start it in the morning. It feels like it is getting gas and trying to turn, but it just doesn't. I changed the spark plugs, which did not resolve the issue.
Once it struggles to start and eventually does, I let it idle for a few minutes and it runs fine. I can turn it off, then back on with no problem. I'm wondering what the problem could be. Ignition coils?
stefanb stefanb is offline
My Saabs: 2003 9-3 Arc, 1988 900 Turbo
Those are random misfire codes. WIS says check fuel grade used, T8 software, spark plugs, ignition coils, injectors, cylinder compression, and fuel pressure.
Old 31st December 2013
nateslaughter nateslaughter is offline
New Member
My Saabs: 2009 9-3 Sportcombi
Originally Posted by death shot View Post
2007 9-3 2.0T:
Hello,
I'm having the exact same issue/CEL code with my 2009 9-3. Were you able to pinpoint/resolve the issue? Any guidance will help, thanks!
Diggs's Avatar
Diggs Diggs is offline
My Saabs: 2003 9³SS Linear; 2015 VW GTI
Originally Posted by nateslaughter View Post
Hello,
The cold start issue or just the codes? If it's the cold start issue you won't be happy. Lots of 2007-2008 2.0Ts are having this issue due to incorrect (or cast, we don't know) intake valves in the head being put in. Not a cheap fix. See the sticky at the top of this forum. There has been a case of a 2009 with this issue. How many miles on your car?
The answer is almost always....Tech2
Hello,
The gentleman above speaks truth. I did have the issue resolved by the best Saab mechanics in the mid-Atlantic: Sports Car Services in Delaware (My lord what a beautiful Saab showroom filled with classic Saabs!).
The issue isn't really Saab's fault, but basically it requires a valve job as the intake valves were not hardened correctly and start to feather. This causes compression to leak and in really cold weather, you may not be able to start the car.
To me it was worth the cost as I adore my car.
I highly, highly recommend Sports Car Services Saab.
Old 13th April 2015
joeamici joeamici is offline
New Member
Default Saab 93 2004 CODE P0300
I have changed the Coil On Plug Boot for cylinder and the issue went away , sometimes you might have an actual bad coil which is a lot more expensive to replace mine were fine, if you are trouble shooting the actual coil you will need to figure out the correct resistance for you coils , you can do that by pulling out all 4 and measuring each 3 of them should have the same number and one should be different , you have to check each prong connection , you have 4 on each coil - this part you have to make sense on your own make sure you test, in my experience, a good coil would have reading for each connection you make, a bad one would only give 2 or 3 reading out of all 4
Old 6th February 2016
Greasemonkey199 Greasemonkey199 is offline
My Saabs: 04 Linear 9-3 2.0T
I have the same problem but no check engine light. No power loss, no vibration.
Diggs's Avatar
Old 7th February 2016
Artfulkatana's Avatar
Artfulkatana Artfulkatana is offline
My Saabs: 2003 93 Linear
Garage
Coils. Replace them, nature of the beast. This topic is beating a dead horse that's been buried for 10 years.
Sent from my SM-N910P using Tapatalk
"If only I could pull this part off an TSIO-520..."
Old 26th August 2016
tad.w.hope tad.w.hope is offline
My Saabs: 2003 Saab 9-3t
OK so I have the same P0300 o. My 2003 saab 9-3t I replaced all the plugs, coils.. what else could this be I did buy "genuine saab" coils, although I did get them off ebay, I sent a pic to my local saab shop ad they said those are definitely genuine saab mitsubishi packs.. any help would be Fanfriggin-tastic
Sent from my SM-N910T using Tapatalk
Diggs's Avatar
They have to look like this. No exceptions.
http://www.saabcentral.com/forums/sh...d.php?t=535961
Yep I got scammed.. I need to find a good source for some real ones
tombalas tombalas is offline
My Saabs: 03 9-3 Linear
Ever since replacing my plugs and air filter (including emptying out all of the leaves that were crammed in there blocking air flow), no more P0300s for my car. It could be as simple as that.
Diggs's Avatar
Autozone Duralast.
Search online for a coupon first. They are pretty easy to find.
So the auto zone ones work?
Diggs's Avatar
Thumbs up
Originally Posted by Diggs View Post
Autozone Duralast.
What this guy said.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
