Engine cut out - SaabCentral Forums
Old 21st October 2010
Todd S Todd S is offline
My Saabs: 2003 9-5 Aero
Default Engine cut out
The engine on my 2003 aero seems to "cut out" very briefly while driving on the highway and engine fully warmed. I am assuming that this is most likely a throttle body issue and needs to be cleaned? Also, not sure if this is related but, a couple oil changes ago my mechanic tells me that maybe one quart of oil came out during change and that the oil looks very dirty (even shortly after change). I have been monitoring the oil consumption and I am not currently burning much oil between 5,000 mile changes (maybe a quart). Possible turbo failing? No smoke at start.
Thanks for any advice!
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
The oil in our cars does get very dirty very quickly - strange but not a worry really.
Your cutting out could well be a crankshaft position sensor failing.
I would however start off with a fresh set of correctly gapped NGK plugs!
Replaced the CPS not too long ago. This cutting out is not causing an engine light. I guess I will try the plugs. Not sure how long ago I changed them. What do you recommend?
How frequent do you change the plugs?
richokop richokop is offline
My Saabs: 9-5 3.0 griffin
how long ago did you replace cps, when mine went no cel came up
Replaced the cps 15,000 miles ago.
Jssaab Jssaab is offline
My Saabs: 2000 9-5 Parts, 2003 Aero Hirsch "Clone"
Use only the prope NGK plugs in you manual al lthe rest can casue the problems you state
Old 22nd October 2010
can`t be cps then, so i would go with the sparkies then.
as said above use ngk`s.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
