suspension making rubbing/crunching noise? - SaabCentral Forums
Old 20th October 2010
spg1 spg1 is offline
My Saabs: 2008 Aero 95
Default suspension making rubbing/crunching noise?
My 2003 saab 95 is a great car, but there is one thing that I hear all the time when driving over bumps and uneven surfaces like driving into my driveway from the road.
The sound that I am hearing is like thin plastic rubbing on a ruff surface. It's almost like as if I had a plastic sleeve over the shock or something and it rubs every time it moves up and down.
It could also be described to sound like a muffled bag of chips being crunched.
Any Ideas? I have looked and I can't see anything.
Maine Maine is offline
My Saabs: '04 9-5 Arc/'99 9-5 SE/2000 9-5/'97 900S
How are your sway bar end links? I am getting a crunching sound over bumps and my links are shot.
It does sound like it is in the rear of the car. Is there a picture of the offending part and location that I can get my hands on?
I'm sorry I thought you meant the noise was from the front of the car, not sure there are any rear links to go bad on these cars.
However, I am also experiencing squeaks from the rear and other weird noises, I just looked and couldn't find anything either.....
Old 21st October 2010
5XSaabOwner 5XSaabOwner is offline
My Saabs: 2004 9-5 Linear Wagon
Check out www.platonoff.com
some of hs tutorials are here.
Sounds like front/rear control arm bushes is a good place to start. If you want to replace yours i have a near new set of oem front bushes for sale in the classifieds
Thanks, but I know it is from the rear. I will have a look at it again, but from what I have been told, there is now rear control arm.
Oh, but there are
Lex Andrews's Avatar
Lex Andrews Lex Andrews is offline
My Saabs: 1998 2.3t 9-5 Saloon.
May be different. I have a '99 Estate, mine has smaller versions of the drop link bars, and a swap bar. Not sure if the facelift has these as well. The droplinks are about 3-5inches in lenght.
Is the car rolling into corners? I've found the droplinks and swaybar bushes make a metallic rattle when going over bumps. Just replaced my front droplinks and LHS sway bar bush.
I really should stop taking the car to pieces. It means I know things
It has the drop links but the sound that I am getting isn't metallic at all. The car handles quite nice and doesn't roll into the corners in a bad way, very stable.
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
Rear trailing arm forward bushings. Lie down next to the car and have someone bounce the rear bumper - if the noise is forward of the rear wheels this is your problem.
Thanks, I will check it out.
Old 23rd October 2010
Mac is spot on, these are the root of my noises. I started another thread with sources for these bushings.
Can you provide the link to the thread?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
