NG900 2.3 NA turbo? motronic to t5 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab NG900, 1994-1998 and OG9-3, 1999-2002 & '03 Convertible (NG=new gen/OG=old gen) > NG900 & OG9-3 Performance, Mods & Tuning
NG900 & OG9-3 Performance, Mods & Tuning Covers Tuning & Performance modifications for the NG900 (1994 to 1998) & OG9-3 (1999-2002) & '03 Convertible
Old 17th October 2010
SebastianPi SebastianPi is offline
My Saabs: 1996 900s 2.3 141k 5spd 5dr
Lightbulb NG900 2.3 NA turbo? motronic to t5
I understand that the 900S 2.3, the 9000 CSE, and the 9000 aero used the same engine.
i was planning on eventually modding my 96 900 NA to be similar to the 9000 (maybe even swapping in a larger turbo), my engine only has 130k so i would like to keep it.
however, i have no idea about the computer systems, as i have never owned a saab before. Is is impossible to switch the motronic with the t5?
also, should this be in the 900 or 9000 forums? please excuse me if i am incorrect.
thank you,
sebastian
grkguy89's Avatar
grkguy89 grkguy89 is offline
My Saabs: 97 900SE, JZW Stage HX35 w/m injection
Garage
wow i wish a good search function was available on this site so you could look at my threads where i did all that you are talking about
EDIT: ill look through my threads and post the link here in a few
Christos (VA saab meet pm me?) JZW Tuned Stage 7
grkguy89's Avatar
Garage
diff links pertaining to what you're talking bout... in no specific order
http://www.saabcentral.com/forums/sh...d.php?t=171103
http://www.saabcentral.com/forums/sh...d.php?t=181986
http://www.saabcentral.com/forums/sh...d.php?t=179505
http://www.saabcentral.com/forums/sh...d.php?t=171165
http://www.saabcentral.com/forums/sh...d.php?t=166898
http://www.saabcentral.com/forums/sh...d.php?t=163193
http://www.saabcentral.com/forums/sh...d.php?t=163702
http://www.saabcentral.com/forums/sh...d.php?t=158425
thats all i can find
thank you very much. i had trouble finding such posts myself.
grkguy89's Avatar
Garage
thank you,
sebastian
meant to answer this first
the engine between your car and a 9k are similar but not the same...
you engine has internals (crank, rod, pistons) for high compression
while the 9k engine has internals for a lowere compression to accommodate for the forced inductions from the turbo
they share the B234 part of the engine code, but the letter that follows that (I, R, or L) identifies the rest of the engine's build
the engine code for your car is B234I (N/A)
while a 9000cse will have B234L (low output/pressure turbo)
and a 9000aero will have B234R (high output/pressure turbo)
yea i was hoping all the parts could bolt on fairly well, but i assumed that to get it running smooth i would need to t5 it. thank you very much for the links though, im sure they will prove useful
grkguy89's Avatar
Garage
ya t5 will deff help with getting the car to run nicely... as for parts, you'll read up somewhere that all the turbo parts off a 94-99 900/9-3 2.0 turbo will directly bolt on
you are very limited with the motronic engine management
if you want any sort of power increase from your engine, i'd recommend going to t5 regardless if you want to boost the engine
okay great thanks for the insight man, and a belated excellent work on your t5 turbo conversion! thing sounds sick!
-sebastian
Tags
900 to 9000, motronic, na to turbo, trionic, turbo conversion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
