Turbo vacuum diagram - SaabCentral Forums
Old 5th October 2010
hessdf hessdf is offline
My Saabs: 85 900 Turbbo
Question Turbo vacuum diagram
Does anyone have a diagram of the vacuum lines for an 85 16V Turbo. Mainly interested in the waste gate area and the intake manifold. Turbo is bogging down under heavy throttle.
Jon1's Avatar
Jon1 Jon1 is offline
Default Photos of vacuum lines on 85 SPG
The orange hoses are the vacuum lines on this 85 SPG
Jon1
jon...
Racerquinny93 Racerquinny93 is offline
My Saabs: 93' Commemorative Edition #281 of 325
cool, now is it different for a 93 900 coMED 2.0L turbo engine??????
Old 6th October 2010
TooMany2cvs's Avatar
TooMany2cvs TooMany2cvs is offline
Saabista
My Saabs: '90 900T16 3dr - For Sale!
No, they're both c900 T16s.
Adrian
Soon to be living life on the road in an old VW
Smile
Thanks so much. I think i already see a problem. My vacuum hose coming from the nipple on the intake manifold is going to the FPR, and the picture shows it going to the top of the area with the SAAB cover plate. Could you show me where the FPR hose goes? Thanks
mines a little different
peva's Avatar
peva peva is online now
My Saabs: '94 T16 Ruby 3dr, '93 T16 Ruby Vert.
Doesn't really matter as long as it's from the plenum chamber and is pressurised on boost.
I have sent some pictures of mine. As you can see in #1 the hos has been capped near the oil cap. #2 shows hose coming from throttle body to a canister on driver side fender.#3 is hose going from intake to FPR. # 4 is unused and looks to small to accept a hose. HELP. Had to pit this on forum because I can not figure out how to attatch photos to private message.
ID:	19932   Click image for larger version
ID:	19933   Click image for larger version
ID:	19934   Click image for larger version
Question
Has #4 been broken and someone re-routed hoses?
Old 13th October 2010
saablicker's Avatar
saablicker saablicker is offline
My Saabs: '88 900 16T vert, '91 900 16T Aero hatch
Looks like you are missing a vacuum line there.
In the second pic that Jon1 posted, you can see there is a vacuum line that connects to the inlet on the valvle cover back to the intake manifold, with a check valve (the white thing) in the line. The check valve is there to prevent the crankcase becoming pressurised when you're boosting.
However, assuming you don't have a vacuum leak on the inlet side, not sure how this would impact boost for you. Wiser heads on the forum may know.
I have ordered a new nipple, grommet and check valve and will run that hose, and then take the hose from the FPR and run it to the vacuum port on the other side of the intake maniflod near the break booster. Sound right?
saablicker's Avatar
Yep - sounds good. On mine, I'm running a vacuum line from the side of the manifold, next to the brake booster, across to a T that splits it to the FPR on one side, and the check valve and valve cover nipple/hose connection on the other.
Make sure you get the check valve around the right way. You should be able to suck air through from the manifold side, but not blow - if that makes sense.
Good luck
Great. Will take care of this weekend. Yes the explanation of the check valve made sense to me. Just about have the old 85 running great. Will post some pictures soon. Only have about $1600.00 invested so far. Need to have both front seats reskinned and thats about it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
