Cam shaft retaining bolts, torque specs - SaabCentral Forums
Old 30th September 2010
redciv1 redciv1 is offline
My Saabs: SOLD
Default Cam shaft retaining bolts, torque specs
Putting head back on and need to know the torque specs and order if any of cam retain bolts 8 on each cam.
My Saabs: SOLD
I really need help, i'm in the middle of putting the engine back and can't do anything else until the cam retainer bolts are tightened down. HELP!!!!!
busaboy busaboy is offline
My Saabs: 2000 Viggen 5-door
Why in the world are you attempting a project like this without any manual or specs?
Kei's Avatar
Kei Kei is online now
My Saabs: 1995 900 SE stage 3 @ 188k
Garage
This guide is probably what you are looking for.
Tighten the bolts to 11 ft-lbs, starting with the cap closest to the cams pressing down on the tappets
My Saabs: SOLD
i didn't realize the machine shop was not going to tighten the caps. Everywhere else on here there are specs.
Sooooo, you ride too?
My Saabs: SOLD
Thanks Kei
Old 1st October 2010
Yes'm, and Kei's info agrees with the WIS.
Tweek's Turbos Tweek's Turbos is offline
My Saabs: 07 9-5 Combi, 99 9-3 Viggen, 85 900 SPG
You know what ones go where right?
Specific ones are channeld out for oil passegeways.
My Saabs: SOLD
The Machine shop took them out. I do not know the proper order. Is this posted some where.
The WIS has the info. If someone can tell me how to post a pic from that, I can do that; otherwise, I can rewrite the words. It's not much.
My Saabs: SOLD
thanks
OK - here it is....
"7. Fit the camshaft and bearing caps, start where cams are pointing down and acting on the tappets. The bearing caps are marked 1-5 for the intake side and 6-10 for the exhaust side.
Tightening Torque: 15 Nm (11 lb-ft)
__________________________________________________ _______
Important! The black bolts have an oilway and should be fitted on the spark plug side.
8. Line up the marks on the camshafts with their timing shaft marks."
Old 2nd October 2010
My Saabs: SOLD
Thanks. Good to go. All were in order and black bolts on the appropriate side.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
