Memory seats - SaabCentral Forums
Old 26-09-10
05Aero21's Avatar
05Aero21 05Aero21 is offline
My Saabs: Steel Grey 05 Aero automatic
Default Memory seats
I'm pretty sure I read the instructions right on how to program the seat settings for each driver. I set my seat adjustment for myself and hit M, (hold)then 1. It chimed. I had my wife set her seat adjustment and hit M, then 2. It chimed. When I got in to set mine back, I hit 1 and all the seat did was move forward. If I kept holding 1 it would move forward just as the bar for the forward/back button would do.
I must be missing something........help appreciated.
Old 26-09-10
saabtwin saabtwin is offline
My Saabs: 9-5 estate & saloon & NG900 vert
Hi
Do you not have to press M + 1 at the same time to set it? Ignore me if you did and I misread your post!
Old 26-09-10
J-Rod's Avatar
J-Rod J-Rod is offline
My Saabs: 2003 Saab 9-5 ARC
Garage
I made a video of this if it helps.
http://www.youtube.com/watch?v=QeA_kx62SKY
Old 27-09-10
05Aero21's Avatar
Thanks for posting this...I'll copy and get back to ya!
Old 27-09-10
J-Rod's Avatar
Garage
Any help?
Old 27-09-10
Kamil Kamil is offline
My Saabs: 2001 Saab 9-5 2.3t
quick question, and sorry to hijack your post for a sec.
Can I install the memory buttons on a seat that does not have the memory seats? If so is it pretty easy to do?
Old 28-09-10
Hi
It's not just the button, as there's the actual memory unit under the seat. You'd need to compare the wiring diagrams as well to see if further wiring would be needed in addition to the unit. For example the memory needs a permanent power supply which the normal electric seats don't.
Old 28-09-10
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
Pull the seat off and have a look it may already be pre-wired; you will need the memory module ($1000); if it's wired already pick up a module, memory button and seat trim on ebay.
