Vacuum Line Help needed - SaabCentral Forums
Old 17-09-10
ctown95's Avatar
ctown95 ctown95 is offline
My Saabs: 99 9-5 SE
Default Vacuum Line Help needed
I was changing my valve cover gaskets today and I broke a plastic vac line. I was wondering what it is and where i can i buy a new one. thanks
Old 18-09-10
planosaab's Avatar
planosaab planosaab is offline
My Saabs: 99 9-5 TD04 270hk::2000 Viggen 5-Door
Well that line is similar to the fuel line, you could cut the broken ends flush and just take it to the autoparts store and have them cut you a piece of vacuum or rubber type fuel line with an inside diameter to slip over the plastic line to repair it. that line goes to the brake booster, you can drive it to the store just will make your brake pedal feel really hard to push. regardless fix it asap but the hose to connect the pieces would be the quickest cheapest fix because that way you don't run risk of breaking the check valve when you try and swap it out.
Old 18-09-10
ctown95's Avatar
My Saabs: 99 9-5 SE
Thanks for the info, it accualy broke off a bit of the valve nipple, and it broke off at the intake manifold. It has some knd of system were in clips in to the maifold.
Old 21-09-10
ctown95's Avatar
My Saabs: 99 9-5 SE
Does anyone know where i can get this part from?
Old 21-09-10
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
eEuroparts.com part # 4688206
Old 21-09-10
planosaab's Avatar
Ya what he said, Eeuroparts the way to go for that one.
Old 21-09-10
ctown95's Avatar
My Saabs: 99 9-5 SE
Thanks for the info man
Old 21-09-10
Kamil Kamil is offline
My Saabs: 2001 Saab 9-5 2.3t
http://www.genuinesaab.com/catalog/p...a89cea9e86ae42
Silicone lines. Come's in blue, red or black.
