| Saab 9-3 & NG900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 98'-02' & NG900 |
I've just ordered myself the Koni sports suspension kit from Parts for Saabs.
I wonder if I can get Santa to fit it for me? |
| Sponsored Links | ||
Advertisement | ||
I thought you'd already just done a suspension job on your motor?
That was only the springs and the standard shocks can't cope (the car 'bounces' badly) so I have to replace them. The Konis are the only real option open to me but are cheaper to buy as a kit c/w with springs and bump stops than on their owm...go figure
So this'll be on eBay then?
Koni springs fit Saab new 900 unused. |
Nice one bud.
This is what I'll be getting this Christmas I reckon
Any ideas how much a garage would charge for replacing the suspension?
This figure could be way off though depending on your local garage rates and whether have a 'oh a Saab, that's an exotic that is , jack up the price' attitude. |
Cheers all, Matt |
It goes round corners well though!!! 8) 8) Although I need to replace the front Goodyear F1's which I put on new in Feb... |
My primary aim is to cut out the really loose feel to the steering. The car tramlines very easily, and very alarmingly at times. My girlfriend says she noticed it when I put on new 17" wheels with 225 tyres, but I know it was there before. I noticed it when I first testdrove the car before buying it. The nice chap from the AA said it was cool, so I didn't worry about it, but now its starting to get on my case.
It's starting to drift left as well. I'm sure it's all got to be related somewhere. My secondary aim is to get rid of the (now larger) gaps between the wheels and the arches. Of course, going round corners without roll is always nice, but I do like my teeth the way they are. |
The way Saab mount the steering rack to the chassis, to put it bluntly is cack... Abbott manufacture a steering rack clamp, which is about £300, this properly clamps the steering rack into place, and stops it moving at all... It's quite expensive for what you actually get, and I haven't got one yet, but it's supposed to be excellent. You can see for yourself just how much the rack moves at the moment. With the engine off so the power steering pump isn't on, pop the bonnet, and get someone to wiggle the steering wheel left and right. While they are doing this, look at the bulk head where the steering rack is mounted, and you can see just how much it moves around in it's bushings, which it shouldn't do at all. Having the clamp fitted, should stop the wheels being able to pull around by themselves, and it also stops torque steer. And yes, it's worth getting the suspension sorted to get rid of that annoying gap between the wheelarch and tyres... :wink: |
The Abbott clamp and brace certainly reduce torque steer but they don't get rid of it. I think Abbott claim a 50% reduction in TS with the clamp and brace. The VRK will get rid of all TS. I noticed some TS returning when I grounded my front sub frame brace and knocked it loose. Luckily normal service was returned by tightening it up again. IMO it you are going the clamp and brace route it may be worth the extra £250 on top for the full VRK. It genuinely does what is says on the tin as long as your tire pressures are on the button. :wink:
Now we're back to the old tyre pressure thing again! I've noticed that the higher I run the pressure, the less the car seems to be affected by the tramlining etc. I'm currently running about 33-34 as I didn't want to go too far. |
Have a look here. You can get Abbotts to fit or a local garage you trust or yourself if you are feeling brave.
http://www.abbottracing.com/2002/index.htm Click on 9-3 then Chasis and scroll down to the VRK, click on it and you will have all the detail you need. |
Y'know running a tweeked V6 with its very smooth & linear power curve the torque steer is a lot less obvious, yet because of the engine's higher mass understeer is a bit more of an issue, this kit helps with understeer too doesn't it? [OK I admit I've looked and I'm going hmmm 8) ]
Especially as I may make the push for 215bhp next year. The kit had; Solid steering rack clamps & brace bars Poly bushes for the lower arm Uprated bottom ball joints Brace bar for the lower subframe All for £495 + shipping & fitting Yet I've know 3 people with it fitted to quick 900's and they all say it's worth it. |
So Rob, the clamp comes as part of the full VRK for £495???
... and that's what you got? How much did a garage charge you to fit it, or did you have it done at Abbott's? |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
