| Saab 9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-5 |
#61
So I've a couple updates to report:
The tech recommended against the way I had it installed, since the G2-1100 harness has speaker outs for front, rear, left, and right. I suppose I could tap in right after the amp and probably get better quality sound (albeit low volume) but it's going to take some experimenting. Also, there are some unused line-out pins on the unit's board, so I may try tapping those first to see what I get before doing all the wiring after the amp. |
| Sponsored Links | ||
Advertisement | ||
#62
Glad you're getting most of the kinks worked out. If there's any way at all to run regular line out from the device to your head unit, you should really try it. Doesn't make much sense to have some other device controlling the audio when your head unit can do a far better job (it has equalizer, volume, etc).
As far as the circuit gw0udm talked about in his last post, I also don't quite have the electronics knowledge needed either but I have enough to get me somewhere here. What I do know (or at least think is right): - Just a transistor (or two) should be needed, no relay or op amp - I believe our stereo works on the basis similar to schematic D on the TRS Wikipedia Page (schematics most of the way down) - You would have to find somewhere on the board of the device that provides power only when a bluetooth device is connected. - Possible setup of this would be to have 2 NPN transistors, splice them into the tip and ring connections of the audio connector, with emitter and collector on either side. Small voltage source that only turns on when device is paired goes to the base connection of each transistor. Someone is welcome to tell me that I'm completely wrong on any of that, I won't be offended. If I somehow come across some free time I may try to throw together this type of setup but use an old/cheap mp3 player just in case something isn't quite right. |
#63
Cheers |
#64
I am actually gonna try out this mod, cuz I am tired of playing around with cd's;
I just wanna make sure I understand before I start. Is this right: ![]() Some questions: Now, mp3 player connect could be female or male, right? It depends on how I want to connect it to the mp3 player? Any advise on whether to run a female or male cable? On/Off switch basically activates the Telephone mode? |
#65
If you are definitely going the hardwired route instead of bluetooth, I would get a male cable so that you can plug it directly into any ipod, iphone, or almost any mobile phone or MP3 player. A female cable will work of course but I think your connection options will be limited unless you have something particular in mind. Do you? Cheers |
#66
Would this mod work in conjunction with a bluetooth kit if an ipod was being used for music and a phone was being used through bluetooth kit?
I can't quite work it out but I get the feeling that the ipod would continue to play through the speakers when the phone was answered cause its hooked up through phone input? I know a few people mentioned that they were using both but they seemed to be using their phone as their music source meaning the phone would handle the music cutout. Any idea?? Thanks |
#68
I cannot really see properly on this picture. Are all three cables are soldered to the circuit?
#69
![]() They are. I found just heating the soldered area with the tip of the gun was enough to get the wires to adhere well. I attached the ground circled in red to the area circled in yellow. It was easier to do. My board is a tad different and the area in yellow on mine looks to be a soldered connection if I recall. |
#70
#72
Looks beautiful! Turns out my switching is done automatically so I didn't need to wire one up, BUT this is the exact switch I was going to use when I was planning to put one in. Very nice, clean install.
Got any plans for that CF wrap in the background? Cheers |
#73
identical to mine! Nice work. they look almost stock when installed
#74
Agreed. I almost want to find something that I need a switch for just to used one of these; I would love to replace my non-functional OnStar button with one of these witches that is actually functional.
#75
Thanks guys!
That CF wrap is already on the slide-out part for the keyboard, looks pretty good! |
#76
I just finished the mod, and it works, but I am not sure if it is working properly.
First, with Switch ON, and MP3 player OFF, there is a noise coming from speakers. Sort of like static. Is it supposed to be like that? Second, when MP player ON and Switch OFF, music from mp3 player is still playing in the car with reduced volume/quality. Is it supposed to be like that? |
#77
What is needed is to switch some part of the input cable from the mp3 player (perhaps the ground?) to eliminate the partial muting of the radio signal. I just plug in my phone when required, so it's not too much of an issue... but it would be nice to finally nail it. James |
#79
I installed a microphone jack in the compartment under the Ac. Here is what I am thinking: wire the jack and the switch together, so when I switch it off it kills the incoming signal ...
#80
Some possible words of caution about this mod. I've had it for about 3-4 months now I believe, and I noticed recently that my weatherband tuner on my radio no longer works. Could someone else with this mod try their weatherband and let me know if it works? I'm thinking either this mod disabled it somehow, or the shop that tinted my windows may have damaged the antenna, although regular radio reception is fine. Where is the antenna for radio and/or weather band located, windshield?
EDIT:Nevermind. If this happens to you, try switching between Euro and US modes by holding down the SEEK button when the radio is turned on. Last edited by starlightfury; 01-01-11 at 10:28 PM. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
