Car Doesn't Start, then does - SaabCentral Forums
Old 12th September 2010
Madrasi Madrasi is offline
New Member
My Saabs: 9-5
Default Car Doesn't Start, then does
Someone suggested turning the alarm on and off again, and it worked. WTF? What's wrong with the car? 9-5, 2001. Thanks!
Jssaab Jssaab is offline
My Saabs: 2000 9-5 Parts, 2003 Aero Hirsch "Clone"
More info maybe??? and welcome to saabcentral. Does it start at all cold then not hot? is it cranking? Jut won't turn over?
Old 13th September 2010
New Member
My Saabs: 9-5
Default Cranks
The car lights come on, the little bell dings, but no crank. Somewhere else I read to lock the car and then unlock it with the automatic alarm thing, and I did and it worked.
ivanwakeup's Avatar
ivanwakeup ivanwakeup is offline
My Saabs: MY00 Aero (272hp/295ftlbs T7suite)
i'm gonna take a wild guess and assume you're likely running into problems with the theft alarm. I'd actually remove the module and see if that solves your problem- they are finicky devices that i still don't really understand....
One thing about deer: They have good vision.
One thing about me: I'm better at hiding than they are at vision.
Keemoesaabee Keemoesaabee is offline
My Saabs: 9-5
had similar problem but it was associated with nuetral safety switch.
here's a thread on somebody elses experience with the same issue:
http://www.saabcentral.com/forums/sh...d.php?t=143186
pain in the butt but fairly easy fix.
next will be the crank position sensor.
then the leaking coolant valve near firewall.
and last but not least your alarm module will need a new battery and leaky capacitors replaced.
oh, and welcome to the forums!
New Member
My Saabs: 9-5
Thank you. I will do the neutral safety switch first and will order it online to save some money....
Old 14th September 2010
My Saabs: 9-5
might want to try the water trick to confirm. lol it actually worked for me, kinda cinched the deal.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
