NA tuned or turbo - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Performance, Mods & Tuning
Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900
Old 23-04-02
Smackrazor Smackrazor is offline
My Saabs: '92 Green 900 Turbo wSPG Kit
I'm debating whether or not to go turbo with my car or would it be just as cheap to make a 200hp NA tuned car... maybe 250 hp. I don't want much more than that, just enough to keep up with the audi's and beamers.
Old 24-04-02
Janne Selinummi Janne Selinummi is offline
200 hp requires new camshafts, ported/polished head, new exhaust and improved intake, and also tweaked ECU and FPR.
250 hp, however, would require (in addition to the above mentioned stuff) high compression pistons, mechanical valvegear with high-tension valve springs, improved ignition system, an improved tubular exhaust manifold, balanced rotating assembly and uprated injectors.
So it's not going to be cheap. It can be done, but expect to pay a LOT to get turbo-like performance with a N/A Saab engine.
Old 24-04-02
Hmm... I might just go for 200hp then. If I ever feel the need to go turbo then I wouldn't have wasted too much money then either.
