Cabin fan stuck and won't shut off on 9-3 (you may not need a new part!) - SaabCentral Forums
Old 9th September 2010
lmz lmz is offline
New Member
My Saabs: 2003 9-3
Default Cabin fan stuck and won't shut off on 9-3 (you may not need a new part!)
I've seen a lot of posts on this. One particular helped me a lot when my fan was stuck on, even after removing key from ignition.
It directed me towards the Blower Motor resistor, which looks like an organ.
I noticed that one of the contact had a film on it. I cleaned up the contact,
added some dielectric grease, and then reconnected everything and its working great.
Just wanted to share that, as this parts seems to range from $180 aftermarket to $330 from Saab, and there was no problem with the part
on my 2003.. just the connection.
While I was at it I re-oiled the blower motor shaft as recommended, but
you don't need to remove the blower motor to get to the "organ-like" part
which clips into an air duct from underneath the motor.
Hope this may help save someone some $$.
Old 17th September 2010
baileydane baileydane is offline
My Saabs: 2003 9-3 Sedan
This just happened to my car, so thanks for the post. I want to try this solution first, but I don't know much about the part. Is there a diagram of the Blower Motor resistor available somewhere?
aerojon's Avatar
aerojon aerojon is offline
there are 2 types of resistor...
1 for mcc looks like organ pipes/hedgehog
1 for acc which is silver & black & screws onto the base of the fan housing..
Is still running factory oe coils with Hirsch tune..
lmz lmz is offline
New Member
My Saabs: 2003 9-3
Default Reply
If you poke around the forum, someone show a link to a new Blower Motor Resistor (the one that looks like an organ was my culprit) .. Its not directly attached to motor. It plugs into the plastic duct upside-down behind and to left of bottom left of blower motor. Sorry I dont' have a picture.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
