TCS in 1995 9000 3.0 v6 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 07-09-10
mattman31 mattman31 is offline
My Saabs: 1995 9000 cde
Default TCS in 1995 9000 3.0 v6
Is there a way to disable tcs for good. I saw you can take out a butterfly valve, where is this located? You guys are awesome, I visit this site all the time!!!!
Old 09-09-10
Tazzedx's Avatar
Tazzedx Tazzedx is offline
My Saabs: Griffin 3ltr V6
If I remember correctly, you need do nothing to disable it because when it does not function the butterfly remains permanently in the open position. All you need to do is remove the TCS bulb in your dash and remove the on switch and put a blanking plate in place. Removing the bulb allows you to forget it!! Removing the bulb is not very difficult, just tedious and you need a little patience. But it gets rid of that damn light! It's all I did, I've not had a problem with it. I actually prefer the car without the TCS!
Rgds
Taz.
