Questions working with fuel pump assembly - SaabCentral Forums
Old 6th September 2010
thinkglad's Avatar
thinkglad thinkglad is offline
My Saabs: 2002 9-5 Aero, 1995 900SE Vert. ( Sold )
Default Questions working with fuel pump assembly
When you guys have replaced your fuel pump, using the existing assembly, did you find you needed to replace any of the lines within the assembly? Or is it usually just a plug and play swap? I have the Walbro pump on order, I just want to be sure I have any lines or clamps to do the exchange handy.
Thanks
D.M D.M is offline
you need lines and clamps search for it here you go http://forum.saabturboclub.com/viewt...?f=30&t=228670
thinkglad's Avatar
Thanks for the link D.M. I will be sure to have these items on hand for the job.
Jssaab Jssaab is offline
My Saabs: 2000 9-5 Parts, 2003 Aero Hirsch "Clone"
I just did this. The best way is to cut th ebrass nipple off the old pump and use a short ( like one-two inch) piece of submersible 5/16 fuel line, and two full stainless fuel line clamps. Put the new fuel line over the line with the piece of the brass in there. It will provide a good tiff and strong ribbed piece to realy tighten the hose on there. It also will not crimp the nylon line at all sonce you are not really adding any length just using the cut fitting as a liner. And the submersible stuff is way expensive this way you only use an inch or so. The hose is like 30 bucks a foot otherwise.
thinkglad's Avatar
Yeah I see what you mean, I took the assembly apart a few hours ago I cut the line to the pump from the Tee.
Old 7th September 2010
Oops, missed you by the much...
just make sure you don't put a crimp in you line to get it all in there...
thinkglad's Avatar
Picked up some submersible fuel line today from a place that makes up custom hoses for people with boats and hot-rods, seams flexable, its made of some clear material simalar to the factory line, not your standard nylon braided/rubber typical fuel line, hope its the right stuff......
If they say it is submersible sounds OK, never saw any clear before.
Old 8th September 2010
thinkglad's Avatar
Well if it fails all I can do is replace it and warn others.
LeoLegend LeoLegend is offline
My Saabs: 2001 Aero Wagon
I've never had a problem with using regular fuel line in there, no need for the expensive stuff. Heck, once I was in a pinch and used a plastic tube from a CamelBak, worked for years until I decided to change it.
thinkglad's Avatar
Well I'm still unsure about this stuff...it seams like it should be more substantial than it is...its kind of soft
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
