Ride quality with 18s - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-5 Mk.I, 1998-2009 > Saab 9-5 Performance, Mods & Tuning
Saab 9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-5
Old 29-08-10
ctown95's Avatar
ctown95 ctown95 is offline
My Saabs: 99 9-5 SE
Default Ride quality with 18s
I was wonder how the ride quality changes when you upgrade to a bigger rim. I just went from stock 16 to a set of 18s. I was curious to see what other people have to say about it. The ride seams alot more harsh to me.
Old 29-08-10
ivanwakeup's Avatar
ivanwakeup ivanwakeup is offline
My Saabs: MY00 Aero (272hp/295ftlbs T7suite)
rim size doesnt affect ride quality, tire height does. Thus, when you go up in rim you naturally pretty much have to go down in tire height. The effect is a more bumpy feeling ride.
IMO, 18 is a great size for most sedans. 19 might be where it starts to edge on being too uncomfortable for me. Going from such a small 16 inch wheel though it with naturally feel pretty bumpy until you adapt.
One thing about deer: They have good vision.
One thing about me: I'm better at hiding than they are at vision.
Old 29-08-10
ctown95's Avatar
My Saabs: 99 9-5 SE
I see, well then maybe what im feeling isnt the rim size. Driving down the highway at 65 it kinda vibrates a lot, my 16s did this but not as bad, and at the same speed too.
Old 29-08-10
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
Vibration is a bent wheel bad balance or tire, nothing to do wtih the size. Gong form 16 to anything seem sharshe they are so soft a weak. If you go to 17 then 18 you will hardly notice
Old 29-08-10
J-Rod's Avatar
J-Rod J-Rod is online now
My Saabs: 2003 Saab 9-5 ARC
Garage
Did you leave the suspension alone, or change it? Suspension lowing will make it ride more rough. I think it is probably just a matter of getting used to the thinner tires. Also, maybe they weren't balanced properly when installed or the quality of the tires isn't very good.
BTW, any pictures of the new rims?
Old 29-08-10
ctown95's Avatar
My Saabs: 99 9-5 SE
I just had them balanced at big O and the guy said they were a bit rough but they did improve a bit after I had them balanced, is there anyway to make them true again sorta speack
The suspension is stock, i havent touched it. and ill take some pics tomorrow and upload them. Also I was wondering what tire would be good for a 8.5x18 rim and the vibration could be a engine mount or anything in the engine could it?
Old 29-08-10
kmbaer03's Avatar
kmbaer03 kmbaer03 is offline
My Saabs: '02 9-5 Aero, '08 TurboX, '08 9-5 Aero
Garage
I just bought a set of CHs that are 18x8.5 and I think Im gonna go with 235/40/18...225/40/18 is also a fine choice.
Old 30-08-10
ski ski is offline
My Saabs: 02 95 aero
do the rims you bought match the hub size of your car? If not, get hub-centric rings, they should be available from where you purchased your rims. These will make quite a difference in the vibration.
Old 30-08-10
you need a wheel refinisher that can do straightening
Old 30-08-10
ctown95's Avatar
My Saabs: 99 9-5 SE
I believe i have those rings, maybe one fell out when i put the rims on, ill have to check that out tomorrow. What kind of shops would have a tool like that, and how much do you think it would be? Here is a pic for you j-rod
Old 30-08-10
J-Rod's Avatar
Garage
VERY nice! Those look great. Are they Borbets?
Old 30-08-10
ctown95's Avatar
My Saabs: 99 9-5 SE
Yeah they're Borbet FS
Old 31-08-10
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
That depends on what you use to lower it, cheapo springs = rough ride!
Old 31-08-10
ragtopcav's Avatar
ragtopcav ragtopcav is offline
My Saabs: '98 900 vert, 9000 2.3 stg3, 9-5 waggon
One of the useful things I have learned in my job is a lot about wheels and tyres.
An important point to remember is that it is the air pressure with the tyre chamber that supports and carries the load - not the tyre or its sidewall.
So having huge wheels with low-profile tyres [often with a smaller air chamber] will need a greater operating pressure, it is this increase in tyre pressure that usually gives the stiffer ride. Short sidewalls with high pressure gives great control but poor comfort.
Adding to Chris 9-5's comment, he's right poor springs make things worse. As they'll force the dampers to work harder still.
The trick is to get the overall balance right.
1998 Saab 900se 2.0 Turbo Convertible
1999 Saab 9-5 se Waggon 2.0 Abbot Racing ecu
1997 Saab 9000 cse 2.3 stg 3 (mothballed )
1997 Fiat Punto 1.25 85hp
Old 31-08-10
ctown95's Avatar
My Saabs: 99 9-5 SE
Its on stock springs and dampers
So make sure the tire pressure is correct
