Doing an APC upgrade yourself - SaabCentral Forums
Go Back   SaabCentral Forums > Saab C900, 1979-1993 & '94 Convertible (C=classic) > C900 Performance, Mods & Tuning
C900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic 900 (C900)
Old 23rd April 2002
saab16valve saab16valve is offline
Where do you get the supplies to do the upgrade? Who has done it on their cars?
Old 23rd April 2002
Keith Keith is offline
Loads of people including me have tweaked their own APC's here. I got my resistors from Maplin, got fed up with buying the odd one every now and then (paying more for parking than the bits ) So I bought a school study pack, loads of bits in loads of boxes and a carry box for about 20.
In the US Radioshack should have them.
Old 23rd April 2002
Alanb Alanb is offline
Yeah, as Keith says, lots of us have. It's very easy and cheap to do and gives a big boost in performance relatively safely.
Yes, Radioshack is the best place (although in my experience they sometimes have a limited range of resistors). Alternatively, for the real cheapskate option if you can read resistors (it takes five minutes to learn how to read them) then find an old broken radio/TV/telephone etc and pull out the resistors you need. That's what I did with the APC that Pete Tandino has used!
Alanb
Old 23rd April 2002
Alex's Avatar
Alex Alex is offline
My Saabs: 3dr c900 T16RA, 9-5 Aero Estate
Theres a post some where on this board explaining how to read them. Alternatively, cheat and use a multimeter!!
Old 23rd April 2002
Thanks a lot guys...I really appreciate the help!!
Old 23rd April 2002
87SPGIN 87SPGIN is offline
good ques though how to read the pots when adjusting them i really haven't a clue?
Old 23rd April 2002
Well hear pretty soon I am gonna rip in to the apc and I will probably be coming back on here and ask questions hahaha. Thank god you guys are here
Old 23rd April 2002
automec1062 automec1062 is offline
don't forget that you need more fuel at higher boost levels . i'm running 30 lb fuel injectors (red top) and a adjustable regulator (raises pressure 1 lb per 1 " boost)
mike
90 900 turbo 20 psi of boost
Old 24th April 2002
Really? On the Swedish Dynamics site they say nothing about needing more fuel at higher boosts. Please explain
Old 24th April 2002
Just squeezing more air into the cylinders won't give you more power with a petrol engine. You need to keep the air to fuel ratio correct. So if you add more air you should add more fuel to keep the mixture correct & get more power! For Lucas injection a 3.0 bar fuel pressure regulator is enough to support a reasonable APC tweak but a better option is a Rising Rate Fuel Pressure Regulator (RRFPR) this raises fuel pressure at a rate proportional to boost pressure. The rate is what is quoted for the regulator.
So a 1:1.7 rated RRFPR would raise Fuel pressure by 1.7 psi for every 1 psi of boost.
<font size=-1>[ This Message was edited by: Keith on Apr 24, 2002 1:39pm ]</font>
Old 24th April 2002
hmmmmm, alright that definately makes sense thank you
Old 24th April 2002
Carl Hernandez Carl Hernandez is offline
Hmmmm.
What about the earlier 900T's that sported the Bosch CIS system?
How would you go about as far as injectors and the pressure regulator?
From what it looks like the injectors are not electronicly controled.
I could be wrong.
Old 24th April 2002
Janne Selinummi Janne Selinummi is offline
The 8V Turbo has a Bosch K-Jetronic system, and that is a mechanical system. CIS means continuous injection system, and the injectors indeed aren't electrically controlled.
You can increase fuel feed by setting up a pressure switch that operates the cold start injector above certain boost pressure.
Set the switch to start extra injection at about 85 percent of your max. boost, and you should get noticeably better performance in high boost running.
FPR doesn't need to be changed, usually.
Also the fuel pump is well up to the job even with two extra injectors, like some have done...
Old 24th April 2002
Where would a good place to tap off the boost pressure be?
Are you talking about using a hobbs switch?
'83 900 Turbo 8V
K&N Filter,Silicone Vac. Hoses,Intercooler,Tweaked APC
Old 25th April 2002
how do you measure the pots on the apc circuit board or has noone done have they all bought theirs?
Old 25th April 2002
1) Get a digital multi-meter.
2) Set it to a sensible range.
3) Stick the probes on the legs of the pots.
4) Read the display.
Old 25th April 2002
Carl, you could use the overboost pressure cut off switch for this, it is already plumbed in and is adjustable.
Otherwise any of the rubber hoses attached to the inlet manifold are under boost when the turbo is blowing.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
