Doors unlock but won't lock - SaabCentral Forums
Old 22nd August 2010
Mikaman Mikaman is offline
New Member
My Saabs: 2007 9-3
Default Doors unlock but won't lock
2007 9-3 sedan ... I can unlock all four doors with the remote, or with the switch on driver's door, or with the switch on passenger door. But I cannot LOCK the doors with remote or either switch. The only way I can lock the doors is manually. I have two remotes, same behavior with each one. I can't find any fuse listed int he Owners Manual that says "door locks" or any similar name. Again, the doors will UNLOCK with the remote or switches, but they won't LOCK.
Any ideas? I'm guessing perhaps a bad relay somewhere, since the problem occurs with two remotes and two switches -- that would seem to rule out a remote problem, or a switch problem.
Can anyone tell me which relay & where to find it? Or a fuse location/number?
Many thanks.
Old 23rd August 2010
weapons.loader weapons.loader is offline
My Saabs: 2003 9-3 Linear
Are you getting a lock failure on the CID?
I occasionally get the failure and my rear passenger door does not respond to the key fob or the lock/unlock switch on the driver's side door.
I hope someone can shed light on this.
mrsilent13 mrsilent13 is offline
My Saabs: 04 Saab 9-5 Aero
same issue here with a 2006 right rear door...but it doesnt happen all the time...unlocks fine but sometimes doesnt lock
06 Saab 9-3 2.0T 210 hp 234 tq
05 Balt LS/TC AUTO DOWN FOR REBUILD 350whp...maybe?
3" turbo back exhaust, 60lb injectors, Trifecta Performance Tuned ECM/TCM, Forged, Built, TTR engine/tranny mounts
New Member
My Saabs: 2007 9-3
No lock failure on the CID. weaponsloader and mrsilent, it sounds like you have a slightly different problem than mine. On my car, all four doors fail to lock. It was intermittent for a short time (couple days) but now it is permanent (well, until I fix it).
Can anyone help?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
