Convertible top leaks - SaabCentral Forums
Old 15th August 2010
woywitka's Avatar
woywitka woywitka is offline
Guest
My Saabs: '87 900 T16 vert, 911 SC,914,W123 Diesel
Default Convertible top leaks
Last year I replaced my ratty but leak free original convertible top with a much nicer original top from a parts car 1987 900 turbo convertible that was always parked indoors. The top looks very nice.
But it leaks
I get water from the front around the front rail, leaks on to the sun-visors and drips down. I also get water along the rails.
I used 2 cans of 3M Scotch Guard designed for Canvas. No luck. Filled two tiny holes with some black caulk. No improvements.
The fitment looks good.
Ideas?
Old 16th August 2010
SteveTheFolkie's Avatar
SteveTheFolkie SteveTheFolkie is offline
My Saabs: 1987 900 8V
are you certain it's leaking through the top and not coming in between the top of the windshield frame and the front bow of the top? I had a '72 Impala 'vert that leaked there - turned out the rubber seal was shot.
Dans_t16s Dans_t16s is offline
My Saabs: T16S
If water drips onto the sunvisors then I bet it's coming from the windscreen seal (where it's bonded to the screen frame). Very common. Take off the trim at the top of the windscreen frame (above the sinvisors) and take a look. Hopefully it just needs some mastic screen seal and it's not corroded there.
Dan.
woywitka's Avatar
Guest
Thank-you for the suggestions guys, will take a look.
My triumph herald leaked there as well - however - it leaked everywhere else as well - much like my 356 speedster ...... damn I wish they were in my barn today!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
