Alarm won't activate - SaabCentral Forums
Old 11-12-03
KnoxSaab KnoxSaab is offline
My Saabs: 1995 900 SE V6
Default Alarm won't activate
Went out to my car to go to lunch, hit the button on the key fob to deactivate the alarm and nothing happened. Any idea what would cause this? The button itself appears to be working because there is an LED on the key fob which lights up when the button is pushed. The remote will not activate the rear hatch release either. Any suggestions would be appreciated.
Old 11-12-03
20Ted's Avatar
20Ted 20Ted is offline
My Saabs: '03 Audi allroad 2.7T with tip
Sounds like the keyfob lost its programming. The batteries are most likely about dead - probably just enough juice in them to light the LED on the fob...
I can't remember off the top of my head how to do the "recalibration" between the car and the fob...
Hopefully you have another fob to turn the alarm off and get into the car!
Old 11-12-03
no problem getting into the car. I have just been using the key. the alarm does not activate at all. Do you happen to know if there is a fuse I should check?
Old 11-12-03
20Ted's Avatar
Oops - got that backwards! ops:
There is a fuse or a relay attached it - can't remember which one - if it is a fuse, it will be labelled in the fusebox door, or in the box in the engine compartment...
Old 11-12-03
SaabScott's Avatar
SaabScott SaabScott is offline
My Saabs: 1993 900S
If it is the batteries, you will need to push the alarm / disarm button up to 5 times fairly quickly to recalibrate it to the alarm system.
