How can I make my 93 faster? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab NG900, 1994-1998 and OG9-3, 1999-2002 & '03 Convertible (NG=new gen/OG=old gen) > NG900 & OG9-3 Performance, Mods & Tuning
NG900 & OG9-3 Performance, Mods & Tuning Covers Tuning & Performance modifications for the NG900 (1994 to 1998) & OG9-3 (1999-2002) & '03 Convertible
Old 23rd July 2010
Kyle2112 Kyle2112 is offline
My Saabs: 2000 Saab 93 SE
Default How can I make my 93 faster?
Hi guys. I'm just starting to look into making my car faster, I have a 2000 93 SE, 2.0 turbo, 205 stock horse. I just recently cut off the muffler and put a cone on the intake instead of having the box and rectangle air filter in it. I'm lookin for ways to get more power but I'm not sure how to go about it. I was looking into boost gauges and wanted to up he psi but I don't know what it runs stock and how high I should adjust it without causing any problems by having it be too much. What else can I do to increase the power and make it faster
Old 23rd July 2010
greekone greekone is offline
My Saabs: 1999 9-3 SE 2.0T 5spd
Look into a tune and full exhaust.
Old 24th July 2010
Pyr3x's Avatar
Pyr3x Pyr3x is offline
My Saabs: 1999 SAAB 9-3 SE
Check this website out man it's kinda helpful as far as stage upgrade information goes:
http://www.ericsaabsite.com/Upgrades.html
Old 24th July 2010
Cm452 Cm452 is offline
My Saabs: T5 Suited Stg T28++ 9-3
FuFu dust. Like pixie powder 'cept its for Saabs.
-Cm
Old 24th July 2010
Thanks a lot man, that Eric site looks like it's gonna be a lot of help. I'm installing a boost gauge tomorrow and was thinking of running the boos around 11 psi? I also cut off the muffler and ran straigt pipe to a 4inch tip and added an open cone for the intake, I'm thinking i may add that heat shield after seeing it on that site. I noticed a little increase of power, but I wanna get this car to put out what I know it can
Old 24th July 2010
Pyr3x's Avatar
The 3" downpipe is the way to start!
Old 24th July 2010
comtrang's Avatar
comtrang comtrang is offline
My Saabs: '00 9-3SE Auto, SOLD '97 900 HX35 4??bhp
Garage
How did you choose magic number 11 for boost? And are you planning on doing that with a manual boost controller or a tune? Regarding the exhaust, a 4 inch tip won't really do much for you except maybe change the sound. If you're looking for a any power, replace your downpipe and the rest of the exhaust system. Consider the shape of a bottleneck; you need to flow a larger volume straight from the beginning. Without that, the rest is negligible.
New to tuning Saab's? Start
-Branden
Old 24th July 2010
GarrettCharger's Avatar
GarrettCharger GarrettCharger is offline
My Saabs: 06' 9-3 Aero 6-spd
EDIT:: the info below is now correct, however it is not very useful now that i realize the vehicle in question is in fact an SE.
The 185 Hp version runs 10psi stock, so you may want to up the boost a little higher. The stock ecu is airmass limited to a max of 1000 mg/c so whatever hardware upgrades you make will only let you reach the max airmass value quicker. The stock fuel and ignition maps are created out to airmass values of 1300 mg/c (about 15 psi of boost). This is done so that the same set of maps can be used for the base model (185 hp version) and the SE (205hp version). The base model is simply limited by the max airmass map. The right way to increase boost would be to get the ecu tuned. Taking the BPC valve out of the loop and replacing it with a MBC set to around 15psi would probably work, but I don't reccomend it.
Obviously increasing the boost should be done in conjunction with the proper hardware upgrades (high flow exhaust system, larger IC, etc.) in order to get the full benefit and keep the engine operating safely.
Old 24th July 2010
I hooked the boost gauge up and it's spooling up to 20psi, mind you the roads were wet, but that seems a little high for it being all stock, on a dryer road I was hitting 16, but I haven't added boost just the gauge, I thought thy ran at a stock 7, my turbo meter only goes to the end of yellow, no red, does this sound normal?
Old 24th July 2010
I'll definitely look into that exhaust suggestion, what exactly should be changed tho? Like have bigger all round pipes, what's to be different from the existing stock? I did the 4 inch tip mainly for looks and sound. I'm for sure doing that down pipe suggestion, my buddys telling me the same thing
Old 24th July 2010
Default Brain fart...
Oops. I don't know what I was thinking, you have an SE (the 205hp tune), so 15 to 16 psi is normal. I forgot that the base model had 185hp which is around 10 psi of boost. The 20 psi is still strange though. Did it hold at 20 psi for long, or did it just spike? The stock turbo meter is all relative to the tune, where the top of the yellow block represents max allowable boost (i.e. 10psi for base model, 15psi for SE). Since you have an SE I would reccommend going with an ECU tune if you want to make any significant power gains.
Old 24th July 2010
...what exactly should be changed tho? Like have bigger all round pipes, what's to be different from the existing stock?...
Larger diameter, and less restriction (high flow cat and muffler). 2.5 to 3 inch diameter cat-back with high flow muffler should be sufficient. 3" DP w/ high flow cat is probably one of the most highly reccommended exhaust mods, and for good reason.
Old 24th July 2010
Crothers's Avatar
Crothers Crothers is offline
My Saabs: 00 Stg4 93SE Vert
Did you tap into the right line? Fuel cut is 15 psi on a stock car so you shouldn't be seeing 20 psi on your guage. if your turbo meter is going to the end of yellow thats around 11-12psi so your gauge must be wrong.
Old 25th July 2010
comtrang's Avatar
Garage
Using the stock 'boost' gauge isn't an accurate way of measuring boost but 20psi is indeed wrong. What brand boost gauge are you using and where did you tap the vacuum line?
-Branden
Old 25th July 2010
I'll have to get back to you, I'm pretty sure it's auto gauge, I'll check tomorrow, last night I hit a hump going really quick and it felt like I got air and I smacked my front bumper off the ground, but the car just shut off after the hump, just everything shut off and couldn't start the car again. So just got it towed to the shop, haven't a clue what it couldve been, I'm wondering if there's some kind of roll over switch or fuel shut off? All the power works, lights, stereo etc, but I can't start it back up.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
