Charging the a/c; looking of the port - SaabCentral Forums
Old 18-07-10
aslan's Avatar
aslan aslan is offline
My Saabs: 9-5 Aero
Default Charging the a/c; looking of the port
I got a 2000 Saab 9-5 Aero; and I am looking to recharge my A/C; I found this image on the forum, and wondering if it is correct:
the reason why I am asking is because some people are talking about port behind the headlight or smgt. PLEASE clear it out, which port do I use, and do I use R134a??
thank you
Old 19-07-10
RyanDale's Avatar
RyanDale RyanDale is offline
My Saabs: 2002 Aero Wagon
Hmm, I need to do this for my wifes 9-5. Take a look at this:
http://www.saabcentral.com/forums/sh...ad.php?t=83394
Common sense is not so common.
Old 19-07-10
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
On my 95 it had to be re-filled from behind the passenger headlight; bought the freon with the gauge and did it myself.
Old 19-07-10
aslan's Avatar
My Saabs: 9-5 Aero
Now, which one is it? So confused now
Old 19-07-10
Saaber95er's Avatar
Garage
The system from 98-02 should be the same remove the passenger side headlight (very easy) and you should see the valve. The tools you need would be in your trunk tool kit.
Old 19-07-10
raquettelaker2's Avatar
raquettelaker2 raquettelaker2 is offline
My Saabs: 2004 9-5 Aero, 2001 9-5 SE V6 (sold)
THOSE PICTURES ARE OF A 2002!!! Ignore them.
The 1999-2001 9-5's have the recharge port under the passenger side front headlight. The 2002-2009's have it where it's pictured above.
This is from when I did it on my 2001 9-5, so it would be the same place on your 2000. It looks scary but it really only takes about 10 minutes to get the front off like this.
Old 19-07-10
aslan's Avatar
My Saabs: 9-5 Aero
does it matter whether it is v6 or 4 cylinder?
Old 19-07-10
Nope. It's the same on both.
