(Night Panel) trick does not work anymore for alarm - SaabCentral Forums
Old 8th July 2010
chucksings chucksings is offline
My Saabs: 1999 9-5
Default (Night Panel) trick does not work anymore for alarm
I am having the dreaded drained battery problem with the theft alarm.
I used to be able to depress the Night Panel button after removing the key so as to deactivate the alarm. It would bring up a message "Door Alarm Only."
Not so anymore. Instead I get nothing. In other words when I remove the key and press the Night Panel button nothing happens and the screen remains blank.
One other interesting note: In this condition, when I open the door of the car there is a "dinging" alarm type of sound that is occurring. This dinging when the door opens did not occur when the ole "Door Alarm Only" message used to appear.
Anyone know where I am going astray here? I need the "Door Alarm Only" condition again so that the Alarm will be silenced --- especially in the middle of the night!
Thanks
Old 9th July 2010
19016c 19016c is offline
My Saabs: 2001 9-5, '73 99, 89 SPG
I invite you to join me in the unplug it club. I would guess that the battery has just failed completely.
Old 9th July 2010
My Saabs: 1999 9-5
Default It was the lock cylinder sticking
It was the lock cylinder sticking down. I found the answer and quote it with a video. Thanks
"The little thing that pops up in my video is what tells the car the key is out of the ignition. If it thinks the key is in the ignition it will disable the key's remote, the door chime will chime, the cabin lights won't turn on, and the radio won't shut off by itself. (FYI, you can turn the radio on anytime in the 9-5 by pressing the power button). Next time you take the key out look for that to pop up. Sometime you can tap on it and jiggle it around and it'll pop up. Otherwise try the silicon thing I suggested earlier."
http://www.youtube.com/watch?v=ab5Mfrq-wvA
Old 9th July 2010
planosaab's Avatar
planosaab planosaab is offline
My Saabs: 99 9-5 TD04 270hk::2000 Viggen 5-Door
Also its usually the capacitors not the batteries going on 1 and a half years and no false alarms yet...knock on wood, original batteries and new capacitors.
Old 9th July 2010
starlightfury starlightfury is offline
My Saabs: 2002 9-5 arc
If youre willing to spare about $30 total, have these guys rebuild the alarm siren unit for you. They warranty their work for life and have really good turn around time. I used them for my unit about 6 months ago and its been working well ever since. The listing says they only do 1999-2001 9-5 units, but I emailed them about my 2002 and they were able to fix it. The only difference after 2001 is that the siren unit is sealed with glue instead of held together with screws. All i had to do was carefully saw it open, drill a few holes, and add my own screws. Apparently they would have done this for me anyways, but I did it before sending my unit to them in an attempt to fix it myself. When I got the unit back they even added more screws and sealed the tiny gaps a not-so-perfect saw job on my part created. Of course you have to remove the unit from the car, but that takes no more than 20 minutes. Just remove the left front wheel and the plastic lining around the wheel well, and it is right there by your windshield wiper fluid tank.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
