Saab brake problems - SaabCentral Forums
Old 8th July 2010
kichikov22 kichikov22 is offline
My Saabs: 2000 saab 9-3 se
Default Saab brake problems
Hi I have saab 9-3 se and I had a problem with the brakes. The brakes start holding the wheels so hard after 10-15 miles drive. Before that everything is fine. I bleed the brakes and after 5-6 miles same thing. I could drive it. The car was so hot and the brake rotors were blue. It almost start smoking. We bleed the brakes again and the wheel were turning fine. Than again. Please anybody with the same problem. The heat damage my alternator the day before. I stop driving the car. Thank you very much.
Old 8th July 2010
busaboy busaboy is offline
My Saabs: 2000 Viggen 5-door
Check your flexible brake lines. I bet they have deteriorated inside so they're swollen, and they don't let the pressure off the calipers after you've applied the brakes. Plenty of reading and some personal experience on this one....
Old 8th July 2010
Default Is it possible vacuum pump or break booster?
Last week I start feeling that the car wasn`t running good, because the break were appling without any reason. Like I said now the car is almost unmovable, because the calipers are so tide. Today we bleed the brake twice and the car start moving fine for 15 minutes and then again. Don`t you think it`s a vacuum pump or brake booster. Thank you very much for your time. I am so disappointed from my car. So many problems for 2 months.
Old 9th July 2010
jahna jahna is offline
My Saabs: 2000 9-3 SE
Vacuum/brake booster would mean that you won't have power brake assist. I don't think that's your problem.
As busaboy mentioned, check the rubber hoses running from the caliper to the brake lines. If these are in poor condition they can collapse/expand causing all sorts of brake issues.
Old 9th July 2010
Once again a reminder: check the SIMPLE, CHEAP things FIRST!!
Old 9th July 2010
Thumbs down Break booster
I open the break booster and was full with oil.probably that's the problem
Old 9th July 2010
fiveiron9688's Avatar
fiveiron9688 fiveiron9688 is offline
My Saabs: '98 900SE vert - GREEN!!
Dude, did you check the rubber brake lines at all like others have been saying??? Do that.
I'm not sure what the brake booster is supposed to be like, but even if that is the problem, still check those lines. I know I should replace mine sometime (hopefully with some nice stainless lines)
Scarabe green '98 900SE turbo vert - Stage 3+
My pride and joy...when she's not broken
Old 9th July 2010
what do you mean you "...opened the brake booster?" You opened the vacuum can?
Old 9th July 2010
Default Oil in Break booster
No, I can pour the oil out of it. It was engine oil and more than half quart. Is it normal to have oil in the break booster. I am not a mechanic and I just try to do it by myself.
Old 10th July 2010
98se420's Avatar
98se420 98se420 is offline
My Saabs: 98 900 Se Turbo
Like other have said check your brake lines first as thats the cheapest and easiest to check... Is it only the front? Or rear? Or which rotors are binding up as u say?
GS Open Air Intake,Vig IC,GS V2 Downpipe,Saabsport Catback,MBC+A,GS 22mm ARB,Poly Sway Bar Link Bushings,A/C Removed.
Old 10th July 2010
gnode gnode is offline
My Saabs: 1999 9-3
Take a look here,
http://www.saabcentral.com/forums/sh...d.php?t=186891
oil in the brake booster
and here
http://www.saabcentral.com/forums/sh...d.php?t=135326
Old 10th April 2011
Conasha Conasha is offline
New Member
My Saabs: 2000 Saab 9-3 SE
This is one of the two most common SAAB 9-3 and SAAB 9-5 (2000-2004) issues.
The #1 issue is "Engine Sludge". These above listed cars years are noted for the possibility of your engine locking up due to severe sludge. This is linked to a design flaw. The catalytic converter is located right below the engine. If this fails it heats the converter up to an intense level, thus causing oil to boil and sludge. Over time the sludge builds up, blocking the oil screen and causes critical engine parts to lock-up or fail. To avoid this, users should use synthetic oil and do routine oil changes every 3000-5000 miles.
Replace your oil filter every time. You may even add a engine additive suck as Marvel Mystery to maintain a clean engine.
The #2 issue is brakes applying by themselves. This issue 90% of the time is linked to the vacuum booster assist pump, booster line, and the booster itself. When the pumps fails it allows oil to slowly leak into the booster lines. The check valve fails due to oil corrosion and oil is leaked into the booster. Over time the booster builds up a supply of oil. The inside of the booster gets ate up by the oil and the booster fails. To fix the issue, simply replace the booster vacuum, the booster 3 way line, and the booster itself. In some rare cases, you may also have to replace the master cylinder.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
