Crankshaft Pulley Removal - SaabCentral Forums
Old 8th July 2010
RickyMac RickyMac is offline
My Saabs: '01 9-5 Aero
Question Crankshaft Pulley Removal
I plan on doing my oil pump o-ring and crankshaft seal tomorrow morning on my 2.3T auto '01 Aero .
I've seen post about removing the crankshaft pulley with just an impact wrench. Is this done with the transmission just in park or do I need to wedge the right disc or fill a cylinder with rope?
Will the pulley come off without a puller?
And finally what is the size of that bolt? 1 1/16" is a little big ;-)
Post are all over the place on this one so I'm looking for been-there-done-that posts.
Old 8th July 2010
gbest gbest is offline
My Saabs: 08 Vert Aero T2
I do it with the transmission in park, with an impact wrench, it's a 27mm socket.
I've never had to use a puller.
2014 Infiniti Q50 Hybrid Sport
Old 8th July 2010
Mike Brennan's Avatar
Mike Brennan Mike Brennan is offline
My Saabs: (4) 2 01 95's; an 08 95 & a 09 93
4cyl oil pump install (with pics) - SaabCentral Forums
Old 8th July 2010
Breau's Avatar
Breau Breau is offline
My Saabs: 2000 9-5 Aero Wagon HOT
Things that will help you with this:
1) Make sure you have huge circlip or snap ring pliers to get the ring out. I think the stretch has to be at least 2 inches. Here are the ones I bought.
2) The socket you need is 27mm so make sure you have one big enough before starting.
3) It would be easier to use an impact wrench to get the bolt off, but you do need to use a torque wrench to tighten it back at 130 ft lb. You can have somebody help you brace the flywheel or there is a a special lock you can buy that will make it much easier.
4) You shouldn't really need a puller. I borrowed one from autozone before I went to do this and ended up not needing it, but it might be different for some people.
Old 14th July 2010
I don't think the impact wrench did anything. I jammed some chisels in the flywheel and used a 20" breaker bar to get the nut loose.
There wasn't a pair of circlip pliers in town big enough for the job so I modified some huge needle nose ($12) and they worked well.
After replacing the o-ring and seal I've found out that my leak is still up at the head. It's probably the timing chain-head connection. I should have used Loctite 518 on the timing chain cover even though the head gasket said not to. How is a gasket supposed to work on 2 different metals under a wide heat range?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
