How to replace Shifter Jalouise? - SaabCentral Forums
Old 8th July 2010
jmcox44's Avatar
jmcox44 jmcox44 is offline
My Saabs: 2001 Saab 9-5 Aero, 2010 Mazda3i Touring
Default How to replace Shifter Jalouise?
A few weeks ago I somehow broke my "Shifter Jalouise" while shifting into Drive. I have the new part, but have no idea how to take the Auto Shift Knob off of the gear shifter. I would use my WIS but since moving to the new house, I have yet to set up the garage computer (only comp running windows xp, since WIS doesn't work on 7). Any ideas?
Here is a picture for those that don't know what I'm talking about:
Old 8th July 2010
Nathan 9⁵'s Avatar
Nathan 9⁵ Nathan 9⁵ is offline
My Saabs: '01&'03 9⁵ 3.0t '04 9 2.0T '06 97
Very carefully with the help of this
...Notice the poster on scribd too
Old 8th July 2010
Apocaliptic Apocaliptic is offline
My Saabs: 2003 Saab 9-5 Arc V6 3.0t
Where you bought this part. I'm searching for that too, and how much it cost?
Thank you
Old 8th July 2010
Wulf
Guest
Posts: n/a
Thank you
I saw it on the eEuroparts site the other day:
http://www.eeuroparts.com/Main/PartD...spx?id=4777173
Old 9th July 2010
jmcox44's Avatar
Thank you for the help, but how exactly do you "Dismantle the Selector Level Casing"?
I bought the part from thesaabsite. Here is the link:
http://www.thesaabsite.com/shop/sear...1=Start+Search
Old 9th July 2010
Old 12th July 2010
jmcox44's Avatar
Bump for any ideas. I really need to get this installed...
Old 12th July 2010
Wulf
Guest
Posts: n/a
Aren't these the instructions?
http://www.scribd.com/doc/33071059/Lever-Casing
Old 12th July 2010
jmcox44's Avatar
Wow, yes. Sorry, I didn't even see it on the right in the original link.
Am I reading it correctly? Do I have to unsolder the sport button to disassemble the lever casing?
Old 1st August 2014
Echeban Echeban is offline
My Saabs: 9-5 Linear 2002
Default how 2 replace the jalouise 2002 9-5
I read many posts and finally...
You need:
- torx and flat screw drivers, small pliers, masking tape, small mirror.
* I used a small mirror (a compact that I stole from my wife) to do everything while comfortably seated on the driver seat.
* I used masking tape so parts that fell off were trapped like flies on fly paper.
1- pry off plastic around the shift plate. a small flat screwdriver is all you need. be gentle.
2- put the ignition key ON so you can move the gear to D. close the door or else the ding-ding will drive you nuts.
3- cover all the holes with masking tape to avoid loosing parts down the transmission. put more masking take with sticky side up to catch said parts. It looks like a baby bib. see pic. 007.
3- next you have to remove the torx screw above the clutch lever. it is hard to see but it is there. pic. 010. It comes off and likely stays there for you to grab with pliers but if it falls the masking tape will catch it.
4- pry off the front of gear stick. use small screw driver and be gentle.
5- remove the circlip with pliers. pic. 005. it comes easy but may fall. the tape will catch it. Once you remove the circlip you can take the clutch lever out.
6- my 2002 9-5 has connectors from the 2 wires to the Sport button. Some SAABs may have them soldered. Disconnect.
7- Now you can take the out the back of the stick.
8- Remove the masking tape, then pry off the shift plate. you can see the plastic tabs around it. it is easy but be gentle. do not take it out completely because the Winter button is still connected.
9- Lifting the shift plate just so, you can put the Jalouise in place w/o cutting it. I paid good money for it, so I was not about to cut anything!
10- Engage the clear plastic tape on left to the Jalouise.
11- Lower and snap the shift plate.
12- Put the back of the stick. Reconnect the Sports button.
13- Put the clutch lever. Insert the circlip and make sure the rod moves up/down with the lever.
14- Put the front of the stick.
15- Put the torx screw. It is mighty hard to set with your finders. I user a magnetic driver to set it in place. pic. 008. Unfortunately my mag driver is phillips, not torx, so I just set the screw in place, put pressure with my pinky, removed the mag drive, and inserted the torx. All this while looking at the mirror. no sweat.
16- done! pic. 012.
ID:	102434   Click image for larger version
ID:	102450   Click image for larger version
ID:	102458   Click image for larger version
ID:	102466   Click image for larger version
Old 1st August 2014
soccerrplyr's Avatar
soccerrplyr soccerrplyr is offline
My Saabs: 1999 9-3vig clone 2000 9-3vig clone 19t
Garage
You can get an aftermarket one of ebay for $18. Honestly, the easiest way, a-be-it the half assed way, is to snip the side of the strip where it is the thinnest, pop the shifter trim cover up, slide the strip around and on the shifter area, put a dab of super glue where you snipped, push the trim cover back down and you're done. Takes less than 5 minutes, works great and has been fine on mine for years.
Old 2nd August 2014
I am surprised cyanoacrylate (super glue) bonds rubber, being a contact adhesive that needs pressure to harden, and works well when surfaces match perfectly, like broken china and other hard materials; but hey, it works! I am a mechanical engineer and like to take things apart
Old 2nd August 2014
Garage
I just put a dab on because, not really needed
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
