A couple of tips about thermostats and hot running engine - SaabCentral Forums
Old 06-12-03
fura fura is offline
Default A couple of tips about thermostats and hot running engine
Hope somebody will find these tips usefull 8)
1. OEM Saab thermostats are manufactured by Motorad. So if Motorad thermostats are available at your local autoparts shop, it's should be possible to get OEM quality thermostat at lower price (of course thermostats from Saab are not very expensive too :wink: ).
2. If engine temperature gauge starts behaving strangely and indicates hot running engine it doesn't necesserily mean that you've got cooling problem (like thermostat failure).
Check how the temperature gauge reacts to electric load - if it jumps when turning on/off the lights, ventilation fan or rear window defroster, then you've got electric gremlin
Check temperature sensor connectors at thermostat housing for corosion and clean them by pluging/unpluging a few times. Also check ground points in engine bay for corosion and lose ends. This should fix your "hot" engine :wink:
Old 06-12-03
DrSquirley's Avatar
DrSquirley DrSquirley is offline
My Saabs: '89 900S 3dr | '90 900S 4dr
are they the same same 3 way style thermostats? i replaced my thermostat two weeks ago but only with a 2 way is this accepetable or should i go right to a 3 way saab one? :-??
Old 06-12-03
900 spg 900 spg is offline
I remember reading that one should ONLY use the 3 way kind. I think it was on townsends site or somewhere else. by the way, thermostats are not that expensive even when you get them from an official saab parts supplier. besides the small hole on the body, which should be aligned to be on the highest point was put there on saab thermostats to enable to let air out of the system. very important. you do not want hot spots of air in the head, do you?
best regards
dusan
Old 06-12-03
Well, I don't think that making two lines of thermostats for the same car (one as OEM and another for aftermarket) makes any sense.
BTW I don't understand how can the hole on the thermostat body be aligned to be on the highest point, as thermostat housing and it's body are horisontal and have no highest points I simply installed new thermostat in the same position as the old one and let the engine run for a few minutes with coolant tank cap off. I saw lots of air bubbles escaping through thin hose connecting radiator to coolant tank.
Old 06-12-03
DrSquirley's Avatar
best regards
dusan
i just talked to my "mechanic", good friend of mine that works at saab garage and he says as long as its funtioning, that the 2/3 way doesnt matter.
Old 07-12-03
MSOEMiller's Avatar
MSOEMiller MSOEMiller is offline
My Saabs: '87 900 8v N/A & '88 900 SPG, Both 5 spd
Align the thermostat's air-hole with the bleeder valve.
Old 07-12-03
I did that unintentionaly, as the old thermostat was aligned and I put the new thermostat in the same position
Old 07-12-03
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
This is the case for 8v engines. However, the thermostat on a 16v engine is vertical.
I just cannot agree with that. If your temperature gauge shows 2/3rds when cruising at average speeds in moderate ambient temperature, then IMO that is around 1/3rd too high and further investigation is required (blocked radiator or sticking thermostat would be the first places to start).
Be aware that many 900s are still fitted with their original radiators, and many will have had their cooling systems refilled with tap water. This causes a lot of scale build up inside the engine's waterways (same as you'll find inside your kettle) (this is one of the causes of headgasket failure). Much of this junk ends up in the radiator (better there then in the engine) but over time it'll cause a loss in cooling efficiency.
Old 07-12-03
Jezzadee's Avatar
Jezzadee Jezzadee is offline
My Saabs: Yamaha FZ6 Fazer
I just cannot agree with that. If your temperature gauge shows 2/3rds when cruising at average speeds in moderate ambient temperature, then IMO that is around 1/3rd too high and further investigation is required (blocked radiator or sticking thermostat would be the first places to start)."
I think by 2/3 way he means 2 or 3 way thermostat, not two thirds of the way on the gauge. I think.
You're absolutely right about limescale.The water here is foul - we get rocks growing out of the tap - so I use Brita filtered water. Seems to keep the kettle clean, so I hope my radiator is gleaming inside.
Old 07-12-03
DrSquirley's Avatar
yeah, 2 or 3 way thermostat
Old 07-12-03
Jezzadee's Avatar
While I doubt the 2 way one would do much harm, the heater never seems to get hot with them, only warm. Also they seem to have more of a reputation for sticking, for some reason.
Old 07-12-03
gorper gorper is offline
My Saabs: 86 turbo'd notch & 89T
I have read -- on internet, so maybe it's complete BS -- that the three-way stat does, in fact, have a real purpose: it shuts off coolant to the heater when the car gets hot, apparently because sending it through the radiator is the better way to remove heat.
Old 08-12-03
talking about "stones in the water". has anyone done any descaling of the cooling system and with what? I am afraid that my car has in the past been run with regular tap water for quite a while as the liquid looks pretty muddy.
any suggestions?
thanks.
dusan
p.s. I have had to get a new radiator recently as the old one was pretty much clogged up.
Old 08-12-03
uberfast's Avatar
uberfast uberfast is offline
My Saabs: 1986 Saab 900 16v Turbo
As for the heater... if you turn your heater on the core will help cool down the engine. Muddy water is rusty water that just needs to be flushed out. Good old fashined cooling system maintenance is the cure. Since I live in the middle of a desert I just use water in the radiator. Antifreeze isn't as good of a heat conductor. I heard something about a product called water wetter. Supposed to make water even more heat conductive. I don't really know.
Old 08-12-03
Matthew's Avatar
Saab Mad
More information here:
http://www.saabcentral.com/forums/vi...=150048#150048
You're right - antifreeze isn't a very good thermal conductor. However, you need to run antifreeze in your car otherwise the engine will rot from the inside out. The antifreeze is required for the corrosion inhibiters. Alternatively, find the raw inhibiting additive and add that to the water you put into the cooling system.
Old 08-12-03
Thanks for the link...
Old 16-12-03
Matthew's Avatar
Saab Mad
Came across a post about Water Wetter this afternoon which might be of interest to you:
http://www.saabcentral.com/forums/vi...?p=18832#18832
