A/C and Heat not working... Help?! - SaabCentral Forums
Old 21st June 2010
Hoffman720 Hoffman720 is offline
My Saabs: 2000 Saab 9-5 Aero
Default A/C and Heat not working... Help?!
I own a 2000 Saab 9-5 Aero that the A/C and heat stopped working in. For a week or two it would work when it felt like it and then one day it just stopped working completely. I believe its just my cabin fan which is what I plan on replacing but just was wondering if anyone has had any similar problems to this and what they had to replace...
Old 21st June 2010
mbachand05 mbachand05 is offline
My Saabs: 2001 95 aero
is in not not blowing air all together? and if so i would try to put power straight to the blower motor. just to see if it works or not. and if it does work then i wouls suspect the blower motor resistor
Old 21st June 2010
Yea... if you turn on the heat or front defroster you do feel the warm air coming out of the vents but you can't hear the blower working at all.
Old 22nd June 2010
RacingComputers RacingComputers is offline
My Saabs: 2000 9
Default Not a Hi Jack However
Our new to us 2000 9 - 5 156k ACC has exactally the same issue.
Replaced Fuse # 22, with no result.
Performed various code display options, with no result.
Tried holding the Auto and Down arrow buttons at Start Up to No Avail.
Have read fan motor replacements posts, plan on "hot" wiring fan motor this weekend.
Fan control on the dash shows that the fan is at the top of the speed range, but no sound, or air coming from the vents.
Thanks
Old 14th July 2010
g00s3's Avatar
g00s3 g00s3 is offline
My Saabs: 2000 95 Aero
Default Same here
Worked on the way home one day and 2 hours later I got in the car and NOTHING! No fan noise and no air coming out at all! I have checked all fuses and they are fine. Please let me know what you find on your issues if anything!
Thanks
2000 95 Aero
Old 19th July 2010
WhiteAero WhiteAero is offline
My Saabs: '00 9-5 Aero
I'm having the same issue with my 2000 9-5 Aero also. Display shows fan is on high but the fan in not on. I recently had the system recharged and I can feel cold air comming out of the vents but there is no "assistance" from the blower.
Any solutions yet?
Old 19th July 2010
ctown95's Avatar
ctown95 ctown95 is offline
My Saabs: 99 9-5 SE
When i first bought my 9-5 i had this same problem. I was thinking of replacing the fan but i decided befor doing that I would take it out and clean it just to check it out. I took it out, then pulled the cover off of the fan motor and took the bushing out then cleaned them. I then plugged the motor in and it started spinning like new. I would advise doing this since it costs alot for a new blower motor. I was very happy when i realised i didnt need a new blower
Old 19th July 2010
I was trying to get to the motor yesterday but couldn't get the stinkin wiper arms off to get to the motor. Any tricks to getting these off?
Old 19th July 2010
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
Try one of these you can get one for 5-10 bucks; or loan it from AutoZone.
Old 30th November 2011
sdime811 sdime811 is offline
New Member
My Saabs: 01 9-5 3.0t
Thumbs up Blower motor issue or resistor?
im somewhat mechanically inclined but im stumped... fan quit working one day so i checked the fuse and it was blown, so new fuse installed and much to my surprise it blew again... with the new fuse it will work for about 15 or 20 minutes then it goes... sounded like a ground or short, so i checked everything and found nothing... someone please help! its getting damn cold and the heated seats only warm my ***, not my face... thanks in advance, any and all help is appretiated.
Old 3rd December 2011
New Member
Smile
Anyone?
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
New or rubild your blower....
bob3000's Avatar
bob3000 bob3000 is offline
My Saabs: 2000 9-5 AERO 5spd man MPS STG2
http://photo.platonoff.com/Auto/2006..._Motor_Repair/
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
