9-5 Aero Check Engine Code P0107 - SaabCentral Forums
Old 28th May 2010
OpenRoad OpenRoad is offline
New Member
My Saabs: 2003 9-5 Aero
Default 9-5 Aero Check Engine Code P0107
I have a 2003 9-5 Aero with roughly 120,000 miles on it. My check engine light came on recently and the code read P0107, which as far as I can discern is Manifold Absolute Pressure Low Input or Pressure Sensor Input Shorted to Ground. The car runs a bit rough but does not go into limp home mode. I replaced the boost pressure control valve (it needed to be replaced anyway; the light was on before I replaced it and came back on after I cleared the code). I've visually inspected all hoses and connections and can't find any leaks. I'm leaning towards replacing the MAP Sensor itself, but am willing to try anything else first.
Can anyone shed some light on what this might be? My nearest Saab dealer is about 80 miles away and the closest independent specialist is about as far; taking this car to the shop is not a simple task. Any suggestions would be greatly appreciated.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
