Slow return clutch pedal? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 24th May 2010
wrightbenz wrightbenz is offline
My Saabs: Silver 97 Aero Black 97 Aero 98 M3 SC400
Default Slow return clutch pedal?
So here is the situation. I have a clutch pedal that is slow to come back from the down position. The clutch, slave and line are new the only thing left is the master cylinder and the bushings and spring assembly on the pedal itself.
I pulled the pedal off and looked at everything and it seems fine, aside from some wear on the piece that goes in the spring.
I am guessing that it is the master cylinder but it is working fine, like i said it's just slow to return. What do you guys think?
Old 24th May 2010
speerzie's Avatar
speerzie speerzie is offline
My Saabs: '94 2.0 fpt cse stage 2 T5 suited
sounds like the master cylinder seals have turned inside out. i've seen this on a few vauxhalls, they get a bit cruddy and catch on the cylinder wall.
yesterday is history, tomorrow is a mystery, today is for tuning saabs
Old 24th May 2010
I did have to pump it a lot to get it bleed. I was using a suction bleeder but it didn't work well without pumping the pedal.
Anyone ever rebuild one of these? Also who sells rebuild kits?
Old 25th May 2010
Superaero Superaero is online now
My Saabs: 1997 Aero manual
Could also be the flex hose between the hard line and the bell housing deteriorating internally.
Often it is more sensible to buy a new MC rather than trying to rehab the old one yourself. The cost of a new one isn't likely going to be much more than a kit and your time. If the internals in the MC are scored then you need to machine it so, best bet is a new one.
Old 26th May 2010
I replaced the flex hose during the installation of the engine.
The rebuild kit is $24.00 at the saabsite, so it's a bit cheaper.
Old 26th May 2010
mick44 mick44 is offline
My Saabs: 96 9000 aero 2004 93 2.2 diesel
Thumbs up
master cylinder repair kit... you might get one on ebay or any half decent motor factors about 10 1 spring and some rubbers easy repair ive done it a few times...
Old 27th May 2010
Can't find a kit for the late models for some reason. Anyone know where I can get one for less than the site I mentioned earlier?
Old 27th May 2010
Smile
24$ sounds about right so i dont suppose you will find one cheaper 10 is about the same but if you cant find one pm me and ill get you one and post it to you... regards mick.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
