Please, how do I change rubber door seal. - SaabCentral Forums
Old 25th April 2010
DavidMorgan's Avatar
DavidMorgan DavidMorgan is offline
My Saabs: My SAAB
Default Please, how do I change rubber door seal.
Has anyone changed or knows how to change the black rubber weather strip seal that goes around the front door opening.
It's part number 12758028 and I think it's just a very tight push on fit. I have the new one but am hesitant about yanking the old one off just in case I need to buy special glue first. Do I have to remove the plasic trim off the B pillar that hides the seat belt? If so does it just unclip and do I have to start anywhere special.
These things dont worry me but I have the nasty habit of starting in the wrong place and breaking half of the plastic clips .
I have to change the rubber seal as it is worn out from my ”rear end” rubbing against it when I climb into the cockpit . It cost me 175 Euros or 230 USD .. I should have bought it on-line from the US for only 75 $ ..
Cheers.
.Cheers from a little town 3 hours Saabing SW of Huy
Old 25th April 2010
leetwoah's Avatar
leetwoah leetwoah is offline
My Saabs: 06 9-3 Aero
door seals just push onto the pinch metal! pull old off ! start at center or the seal and work around the door til the ends meet at the bottom
~2006 9-3 Aero~
Old 26th April 2010
My Saabs: My SAAB
Have you ever done this on a Saab 9-3 SS .. or is this just your opinion based on other cars ?
To "pull the old off" I started to try and it is more than tight and some sort of lever will be necessary to start being careful withe the paint.
As for the new "push onto the metal pinch" !!!
I am sure that some sort of tool is necessary so as to pinch closed the strip onto the metal frame. It is not just a stiff rubber strip .. there are two deformable metal cords in there.
"til the ends meet at the bottom" there are no ends .. it is a loop .. as in the diagram
Are you sure that the rubber will slip under the interior plastic trim or should this be partially stripped off.
So as they say in the quizz shows .. Only answer if you are certain
Old 25th May 2010
dragon69185 dragon69185 is offline
My Saabs: '06 9-3 Sedan
So this is a slight late reply to your answer, but I just received my weather seal for my passenger rear and passenger front because of water coming into the car (long story due to the place I ordered it didn't have it in stock and took them almost 3 weeks before I got it) . There is no 'special glue' that is needed (no glue at all), and you just have to pull it off (front was tougher than the rear, but it comes off and there is no specialty tool to get it off). By the ends, start where the seam where the factory had to join the ends on and press it onto the mold that holds the seal (yes, you will have to lift up some of the plastic molding to get the seal in correctly). Take your time and please, oh please, do not used a mallet or hammer (had a friend do that it bent the metal mold because he used a hammer when he changed his seals on his old 240 ). Rear took about 15-20 mins and front took about 30 because of taking it off. Don't know if you have already done it, but yea, pretty easy.
Old 25th May 2010
Saabseeker's Avatar
Saabseeker Saabseeker is offline
My Saabs: 2005 Saab 9-3ss Linear
You just push the thing on. It's tough in places because it's metal-reinforced. Don't bend it.
2005 Saab 9-3SS Linear (daily driver)
2006 Yamaha Morphous
2008 Kawasaki Ninja 500R
Old 25th May 2010
jlrdrony's Avatar
jlrdrony jlrdrony is offline
yes, there is an electric 2 cylinders tool to close the strip onto the metal frame.
Old 26th May 2010
My Saabs: My SAAB
I did it myself but it is a real pain.
When I had finally decided to go ahead .. ripping out the old one was just a question of brute force.
But to put the new one in you will need to "unclip" most of the plastic surrounding trim .. Not easy and MUCH more difficult to replace!
When forcing the new strip into place you will have the impression it is 3 inches too long! You just have to continue around and around untill it is all finally in place.
As for re-clipping the plastic trim in place .. forget it .. close to impossible to get it perfect. I'll try again later.
Another time I'd pay a dealer 1/2 an hours labour for a job well done and no hassle.
Old 26th May 2010
Aleki's Avatar
Aleki Aleki is offline
They replaced mine under warranty, and the outcome of the seam area was less than stellar(it looked like the car was put together by a kia factory). I had them do it all over and they still cant get the new one on right. Guess its something I'll attempt to fix myself :|
PS: I'm talking about tucking the roof liner into the seal, b-pillar not aligned properly, etc...
Old 19th October 2015
FreeSaab FreeSaab is offline
My Saabs: 2003 Saab 9-3 Linear
Default Reversible front door seals?
Does anyone know whether or not the left/right door seals are interchangeable? The used and new parts come rolled up and don't seem to be in any specific form. I keep seeing used passenger side seals for sale but no driver side seals. Are they the same part numbers in WIS?
Old 27th October 2015
Well, I didn't get any responses so I took the plunge and bought a used door seal for the front right side. It does fit the left side front door so they are reversible - so far I haven't noticed any leaks and the trim fit back into place without any issues. I did have to press firmly in a few areas where there used to be corners and its now fitted to a straight section.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
