Charcoal canister full of gas...purge valve...what else? - SaabCentral Forums
Old 23rd April 2010
Moosepuck's Avatar
Moosepuck Moosepuck is offline
My Saabs: 08 vert 2.8t & w211 E55 AMG
Question Charcoal canister full of gas...purge valve...what else?
So... I've narrowed one of my gremlins down to every time I fill up... it get's sporadically rich when I slow down..idle... Disco'd the purge valve on the way home and it did fine.... I pulled my charcoal canister just now and poured out several ounces of gas.... The purge valve seemed to bench test ok, however.........I bought a new charcoal canister and purge valve. What else is there? I'd hate to have put these in just to have it start acting up again.... is there any other piece of that puzzle I should look for? I didn't see anything else on the europarts diagram... Thoughts? (it's a 1997 900SE turbo vert, 5-spd).....
Old 23rd April 2010
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is offline
Saabista
My Saabs: Black on black '97 Saab 3-door SE Turbo
Hey Jeremy, I can't help with the charcoal canister but I can relate to the charcoal canister on my Sea Ray. When the holding tank (kind of like the gas tank) becomes overfilled with gas (with something else), the charcoal becomes saturated and the liquid never drains back into the tank. On the boat, the canister is $100 (unless you cut it in half and replace the charcoal). Hope all is well with your transmission... Ron
Old 23rd April 2010
Moosepuck's Avatar
Hi Ron, thanks for the quick response... my purge valve was full of fuel too... just seems odd that the gas would even be able to get in there in the first place.. Hopefully I'll be good to go now......... Transmission is doing fine so far.....been really easy on it though since the 2.3 build....not for long....we'll see..........
Old 23rd April 2010
Moosepuck's Avatar
and I can relate to the boat parts prices..... everything is at least x2....!! my new charcoal canister was only $37...
Old 23rd April 2010
PMI PMI is offline
My Saabs: 1996 900SE Turbo
Purge valve is your best bet. Usually there will be a CEL, and one of two fault codes associated with the EVAP system. Other than that...
Filler pipe breather or one of the valves at the tank. Air has to get into the tank to replace the gas being used. That air is drawn into the tank past a one-way valve, which is there to prevent fumes from going out into the atmosphere. There is a second valve which closes of the other path, the one to the charcoal canister when the gas tank is full, so gas from a full tank does not get drawn in instead of fumes. (there is a third valve that prevents spills during a rollover, but that is seldom an issue, unless the car is on its side or on its roof, ).
If the two valves are not working together right, gas may end up in the wrong place, or the fuel pump may not be able to maintain fuel pressure, etc...
What you'll often see is that right after a fill-up, the engine will start to stutter and miss, and may stall. If you then open the filler cap to let the air pressure equalize, or even just sit and wait for a few minutes, the problem goes away, untill the next time you fill up.
If you fill up, drive a bit, then stop and crack the filler cap open, and there is a sound like you are relieving a vacuum, something is not working right at the tank.
Old 23rd April 2010
Moosepuck's Avatar
Originally Posted by PMI View Post
.... There is a second valve which closes of the other path, the one to the charcoal canister when the gas tank is full, so gas from a full tank does not get drawn in instead of fumes. (there is a third valve that prevents spills during a rollover, but that is se....
Thanks PMI!!... where can I find this!?? Saab dealer only?... This seems to me to be exactly what's happening.....
Old 23rd April 2010
Moosepuck's Avatar
Does anyone have a copy of a WIS page or two that has this info by chance??.. Ron.....Ron.........?? MRCDMA??? ..... I need to get WIS
Old 23rd April 2010
PMI PMI is offline
There is a pretty long and detailed Saab document on the Evap system. I think I had a copy somewhere. I can look for it over the weekend if you like, but probably can't post it here b/c of copyright etc. If I find it, I can email it to you. I can't remember what the WIS has on the evap system.
Old 23rd April 2010
earthworm's Avatar
Saab Sage!
http://www.saabcentral.com/forums/sh...07795&posted=1
I'd check the EVAP system plumbing, it may just be a disconnected hose from the canister back to the gas tank... Just my idea..
The earthworm
'96 900S, Automatic
Old 23rd April 2010
Moosepuck's Avatar
yes please if you have time.... I'd like to know more about this system as it's one of few areas that I haven't really dealt with on my car.......
Thanks for the tip.....I'll see what I can find between the canister and the tank....
I spoke briefly with a Saab indy at my local watering hole this evening about it.... he said it's pretty common for a piece to fail that's apparently right off the filler neck with a check valve towards the charcoal canister....he claimed it's a Saab dealer only part at about $600 bucks... but he also said he may have a used one he'd give me lying around his shop........ he seems to know what he's talking about... I'd really like to see a diagram of the whole system if anyone has one.....
Old 24th April 2010
Saabista
Hey Moosepuck, I'm headed up to the lake today to have the boat put in. Thw WIS is around 600-Mb, so it woul have to be cut down to 10-Mb pieces and emailed. And I don't have the internet turned on up there yet.
Do a torrent search for Saab WIS and download it with uTorrent. You can do the same with the EPC... Ron
Old 24th April 2010
Moosepuck's Avatar
Downloading it now, not sure why I haven't done it as of yet......have fun on the lake!
Old 24th April 2010
PMI PMI is offline
Done, see link in your SC email.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
