OBDII can't connect. bad ecu? - SaabCentral Forums
Old 9th April 2010
somename somename is offline
Default OBDII can't connect. bad ecu?
My '01 9-5 had been sitting for a few month, and I recently ran it to find it to run awfully. It did run a bit rough before but not nearly this bad. It can't hold idle, surges, and stalls. Any way, I tried to pull codes with my obdii reader but couldn't. I took it to a meachanic, but his reader couldn't connect to my Saab either. Is there something other than bad ECU that could be causing it? Thanks for the help.
Old 9th April 2010
jwwells's Avatar
jwwells jwwells is offline
My Saabs: 2000 9⁵ 5-speed Stg1 207K Miles
Check to see if your throttle body is in "limp home mode" There is a YouTube video which explains how to reset it. Don't know why you couldn't connect the OBDII, but check the throttle body.
2000 9⁵ Black 2.3 5-Speed TD-04, ECUproject Biopower Tuned Stage 1- 196K miles
2001 9⁵ Black Auto Aero Wagon
Old 10th April 2010
I forgot to mention that before I left the car in storage, I installed PCV upgrade kit and also cleaned out the throttle body, hoping to improve the running condition. It didn't really help then, but it ran okay. Any way, it wasn't in limp home mode then. I'll check again tomorrow if it is now. Thanks.
Old 11th April 2010
ski ski is offline
My Saabs: 02 95 aero
don't know what exactly your problem is, but it is not the ECU. The car will not run with a bad ECU (if it were fried) it won't even sorta start and sputter.
Old 11th April 2010
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: 04 9-5 Vector 2.2Tid
Couldn't get a fault code via OBD-II on my Renault, turned out the OBD socket had a 20A fuse on it, we replaced the fuse and hey presto OBD port up & running again.
Old 11th April 2010
mt.aero's Avatar
mt.aero mt.aero is offline
My Saabs: '02 9 Aero, '89 900S
Drain the old fuel and add fresh stuff or if its already pretty low, just top it up with fresh. Gasoline can go bad after only a few months and no longer combusts as it should.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
