apc inline switch - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Performance, Mods & Tuning
Saab 9000 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9000
Old 05-04-10
9000kev's Avatar
9000kev 9000kev is offline
My Saabs: ng900 turbo (stage 0) - polishing
Default apc inline switch
ok it might be a weird question,
i have a stage 2 9000. 230bhp @ 18psi.
i wanted to fit a switch to the apc wires, (i have the t7apc)
i sometimes unplug my apc for long journeys so i am only boosting to 6psi, this is when i need reliabilty rather than performance.
i have sussed out a way (and a route) to fit a switch in the dash board, which disengages the connection on the apc wires at the switch on a button. this is simply so i dont keep having to lift the bonet to connect the wires i can simply turn the apc on/off by a switch.
my question is, Am i doing any damage/harm to my engine by unplugging the apc and runnign the engine only on baseboost? will it fool the ecu within time?
Old 09-04-10
DanF.'s Avatar
DanF. DanF. is offline
My Saabs: 1997 9000 Aero 5-speed
I don't see how it would harm the engine at all.
Silly question... is bhp a measure of HP at the wheels or the flywheel? I only ask because, 1.) I'm confused, and 2.) I had my Aero dyno'd with only a stage 2 software upgrade and it made 227hp @ wheels.
*SAABCentral NEW ENGLAND CREW Member 008* (now in NC)
T5Suite2.0 Stage 3+, Full DIY 3" exhaust w/Magnaflow, Spec stage 2+ clutch, "Custom" airbox mod, Forge BPV, DIY strut brace, Poly bushings, various powder-coated goodies
Old 09-04-10
KPAero KPAero is offline
My Saabs: 1994 9000 Aero
BHP is at the flywheel
Old 09-04-10
Robinb Robinb is offline
My Saabs: '96 9K Aero auto. Maptun Stage 5+
Posted by 9000kev: my question is, Am i doing any damage/harm to my engine by unplugging the apc
Many years ago, a Saab mechanic once failed to reconnect my APC after some work. Everything seemed OK for a day or two, then the Check Engine light came on, code analysis was "multiple misfirings".
Cleared the error, changed plugs, checked all vac lines, same thing 2 days later. Nobody knew what to do about it.
Eventually, I reconnected the APC and hey presto, problem gone.
Old 09-04-10
9000kev's Avatar
wat car was this on may i ask?
Old 09-04-10
A 1996 Saab 9000 Aero automatic. It was Stage 1 at the time.
Old 09-04-10
9000kev's Avatar
ok, thanks for your help.
maybe i wont wire in a switch then.
Old 09-04-10
I think that's a good idea.
Of course, if you want to live a little dangerously, you could just disconnect the APC for a few days and see what happens!
Old 09-04-10
rawill's Avatar
rawill rawill is offline
My Saabs: 97 9000CD,93 9000griffin 92 900s LPT vrt
Mmm, strange that that would happen, I drove for ages with a blown BPC valve and didn't know it.
I got no CEL light.
I will be interested in other responses.
I was going to do exactly the same thing, put a switch in line.
/R
97 9000CD 2.3 St I-T7mod. 93 9000griffin 2.3 St-II. 93 9000CSI na man. 92 900 S LPT vert.
Old 09-04-10
Posted by rawill: I drove for ages with a blown BPC valve and didn't know it.
Not quite sure what you mean by "blown".
If you mean "malfunctioning" there's a fair chance you won't get a CEL error. Just like a "blown" turbo. CEL errors are primarily associated with emission (and potential emission) problems. A jammed ECU or turbo may not trigger a CEL light.
If you mean "electrically disconnected" then your experience hasn't been the same as mine.
Try it - disconnect the APC for a few days and see what happens! I can't imagine my stage 1 was that different from the orginal ECU.
Old 09-04-10
rawill's Avatar
I had no reading on one leg of the BPC valve, I should not have used the word "blown".
Not accurate.
But for the last 3 days I have disconnected it.
This is on my 97 9000CD, I have the valve bypassed and only using base boost.
I have also run my 93 griffin with a blown fuse for an unknown amount of time, when the BPC had failed.
Hope we get some other responses to this, I am intrigued.
Correct I can not imagine a Stage 1 tune would make any difference. But then I am a noobie.
However think about this.
I put a knock led in my griffin, no light on when using the Stage 2 ECU, however, when I put the original (unmodified) ECU in the led came on all the tiime, even when the key was on but the engine was not running.
What is going on here, I have asked about this on the ECUproject yet.
More fish to catch before I worry about that.
I am thinking the resistor I have put in is not big enough, but why is it different between the ECUs.
Old 12-04-10
Posted by rawill: Correct I can not imagine a Stage 1 tune would make any difference. But then I am a noobie.
Compared to the likes of Superaero, Wily Coyote, Skint, Boxman and others on this forum, I too am a noobie. I'm just relieved I didn't blow up my engine while I was running various "tests" a few years ago after reading up on the theory of turbochargers.
